175 "making" oil |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7642 |
Topic: 175 "making" oilPosted: 21 May 2022 at 9:34pm |
I checked the oil in the 175 today and it was over the full mark a fair bit. It does not get used very much. It does smell like diesel. I put a new mechanical lift pump on it when I restored it in 2015. I did put a rebuild lit in it about 3 years ago. Tractor runs beautifully, never had any problems with the CAV injection pump. I am thinking of putting on a new lift pump, but is there anything else that could be causing diesel to get into the oil? Many thanks!
Tom59
Joined: 27 Feb 2021 Location: Lebanon Tenness Points: 161 |
Posted: 21 May 2022 at 10:19pm |
I bet the seal out on the front of the injection pump where it bolts on at the front of the engine. I had a MF275 tractor do same thing with a CAV injection pump and a pump rebuild solved the problem.
nickia
Joined: 11 Sep 2009 Location: alden iowa Points: 793 |
Posted: 21 May 2022 at 10:20pm |
If that tractor has the perkens engine my brothers leaked fuel into the crankcase on the back side of the fuel pump
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3201 |
Posted: 22 May 2022 at 6:04am |
i'd be looking at the lift pump.
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1838 |
Posted: 22 May 2022 at 1:21pm |
Yep a complete pump rebuild and injectors also. Just did my 175 a few months ago. Another reason to pull the dipstick every time before use.
KJCHRIS
Posted: 22 May 2022 at 7:51pm |
2 places I can think of: lift pump or injection pump shaft seal.
