D17 engine swap |
rhoag
Joined: 21 May 2022 Location: Hoosick Falls Points: 6 |
Topic: D17 engine swapPosted: 21 May 2022 at 5:39pm |
Could someone tell me if a D17 series 4 engine can be used in a D17 series 1 tractor? Thank You Rob
DrAllis
Posted: 21 May 2022 at 8:10pm |
Your choke linkage will be different or use your old carburetor. Your power steering pump would have to be grafted onto the newer engine, if you have power steering. Must use your old or reman clutch and pressure plate.
rhoag
Posted: 22 May 2022 at 1:48am |
First Thank You for that information. When you say power steering pump would have to be grafted onto the newer engine do you mean that i would just move the pump from the old engine to the new engine? |
DrAllis
Posted: 22 May 2022 at 6:13am |
Old power steering pump has to be removed from the old engine, mounted and gear lash set on the new engine.
rhoag
Posted: 23 May 2022 at 1:32pm |
Would all the parts from the old engine fit the new engine .I found a series 4 short block i can buy that's been rebuilt. parts from the old engine like head,oil pan ,oil pump ,etc.
DrAllis
Posted: 23 May 2022 at 3:35pm |
Everything should interchange.
rhoag
Posted: 23 May 2022 at 4:07pm |
ok thank you. the engine i have has crankshaft number 229022 . Do you know if the series 4 would have the same crankshaft .
DrAllis
Posted: 23 May 2022 at 6:15pm |
A series 4 will be a different p/n but it directly interchanges.
rhoag
Posted: 23 May 2022 at 7:19pm |
Thank You the information you have given me . It's much appreciated. Rob
