PTO issue |
Post Reply |
Coke
Silver Level Joined: 30 Sep 2018 Location: MIdwest Points: 215 |
Posted: 20 May 2022 at 12:36pm |
Is anyone familiar with this type of PTO connection? Mine won't seem to stay locked on the PTO shaft anymore, is the pin running throughmeant to lock it into the groove on the splined shaft, or is there some other mechanism I'm just not seeing? Thanks in advance. |
1957 D17 Diesel w/ M&W Pistons
8070nc
Orange Level Access Joined: 21 Mar 2019 Location: North Carolina Points: 515 |
If I had to guess Id say the spring on the pin you push to connect or disconnect is broke or weak
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
Allis dave
Orange Level Joined: 10 May 2012 Location: Northern IN Points: 2924 |
The Pin on the end of the PTO shaft has a spring around it on the inside of the shaft. When you press the pin, you overcome the force of the spring and a narrower part of the pin opens up and allows the PTO shaft to slide over the tractor PTO splines. When you stop pressing on the pin the spring pressure should pop it back and the wider part of the pin fits into the groove and locks it on the tractor PTO.
Sometimes the spring get weak and needs replaces. Other times it just gets rusty in there and spraying it with some penetrating oil and working the pin back and forth will free it up
steve(ill)
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 81794 |
soak the pin with penetrant and push it from the LEFT .( tap it with a hammer).. IN/ OUT a couple dozen times... When you PUSH IN and let go, it should POP back out.
Edited by steve(ill) - 20 May 2022 at 1:40pm |
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11634 |
And....if the spring is toast and it won't come back, you pull it out with your fingers once it's in the groove.......probably not the safest or best advice, but been there.
shameless dude
Orange Level Joined: 10 Apr 2017 Location: east NE Points: 13607 |
are you sure you are sliding the connector all the way on? it appears in the pics that you are sliding it on until it stops, that would be the area where that sliding pin is. depress that pin, slide the connector on until the pin slides back again. clean off you PTO shaft and put some oil on it, depress that pin and slide it all the way on to the tractor, then slide it back. oil on both is your friend. even the slide pin.
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 51923 |
If you take a big pair o channel locks, and squeeze that circlip, so that the open side opens up, the circlip is removed, then slide the whole shebang out the button side, the inner workins and mysteries will be revealed to you. Last time I bought one it was about a $3 part, but you never know, with the inflation thingy. They do come in several different sizes, so take the old one with you to your dealer or farm store. If its TSC, I bet they will have the sizes you DON'T need!
PS, take the old one out, clean it, then lay it on a piece of steel, and roll it! If its bent, its toast... Edited by DiyDave - 20 May 2022 at 6:27pm |
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 8123 |
Those can be bought new at any farm dealer or store
MACK
Orange Level Joined: 17 Nov 2009 Points: 7664 |
One picture shows ware on shaft where keeper pin is wareing on shaft. PTO may not be telescoping free or bottoms out when you turn or cross a ditch. MACK
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4951 |
I had that issue, disassembled mine and the spring was broken. New spring resolved the issue. As others said you may be able to disassemble, clean, oil it, and be good to go. Dirt definitely will cause a issue and it could be that simple.
DiyDave
Absolutely right! If it won't telescope, it bends the pin!
Coke
OK, it would appear everybody is right.
So I was at my local farm store earlier (before I took off the clip, cart before horse) playing with PTO shafts to get an idea of how they were supposed to work, now I'll need to go back, or order, a 9/16x3.5" pin. For whoever said I wasn't sliding it on far enough, I had it all the way to the plate on the back of the tractor, I think either at that point the pin had slid out of locking position, or it's just too damn worn. I'm hoping just a new pin and a well greased PTO shaft will give it enough of a bite to stay on, I'm wondering if it's only been friction and the fact the shaft was fairly well greased, that's been keeping it on up to now, because that button has never bounced, I never even realized there was a spring in there until I took the clip off and took it out. Hoping the shaft isn't too worn as well. Thanks folks. Edited by Coke - 22 May 2022 at 10:14pm |
Post Reply | |
