WD 45 Diesel Injector Pump
yesmar74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yesmar74 Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Diesel Injector Pump
    Posted: 18 May 2022 at 3:40pm
I have the injector pump pulled off of my wd 45 diesel to determine if it possibly has a stuck shaft.  The tractor has sat for quite a while and the engine may also be stuck. I didn't want to try turning the motor over until I pulled the pump.   My question is if the pump is not stuck how much effort does it take to rotate the pump?  Would I be able to turn it by hand?
