electrolysis issue |
Post Reply |
Author | ||
TomYaz
Orange Level Joined: 14 Sep 2009 Location: PA Points: 10325 |
Posted: 28 Sep 2010 at 8:16am |
so I am using a 12v battery charger. My sacrificial anodes are two, each approx 24" long, 1" wide and 1/8 thick strip of steel. About half each is submerged. The part to clean is a picee of angle iron approx 2x2x60", Half of it is subermerged. Im drawing too many amps. Battery charger cuts out.... So I am using one anode and not getting the complete coverage I want.. Is there a battery charger that limits the amount of amps it will put out? In other words set it to 10 amps and no more than 10 amps will be used no matter the number of anodes...
Side note. I am using lye...notice that the rust settles on the botton and does not float to the top... I can see the part well thru the whole process.
Sponsored Links | ||
Robert Mull Georgia
Orange Level Joined: 14 Sep 2009 Location: Woodstock, Ga. Points: 211 |
Use a weaker solution( Watered down). I used AC/DC buzz box welder set on DC 40 amps the last time I did it. Doesn't take but about 4 hours. Solution does get warm!
TomYaz
That may be the issue; I did put a lot of lye. will water it down. Thanks!
I just remembered I have one of those Lincoln welders too...but no 220v outlet...
orangereborn
Orange Level Joined: 12 Sep 2009 Location: NW WI Points: 1451 |
Robert....You have a suggested solution ratio? Tom...What lye ratio did you use? Thanks....Dale |
Robert Mull Georgia
The solution I used was the washing soda stuff. You have to use enough to make the water conductive.
Jeff Z. NY
Orange Level Joined: 11 Sep 2009 Points: 7326 |
Tom, When I first read the title to your post I though you might be having a problem removing leg hair. LOL
http://www.hairlasers.com/electrolysis.php |
TomYaz
[QUOTE=Jeff Z. NY]Tom, When I first read the title to your post I though you might be having a problem removing leg hair. LOL
http://www.hairlasers.com/electrolysis.php[/QUOTE] Well your in good company with the female co-workers I talked to about this....(funny how their eyes just glaze over)
TomYaz
three bottles in 50 gallon...how much in each bottle....ummmmmmm?
Lot of sizzling and crackling going on!LOL!
R Aiken
Orange Level Joined: 11 Sep 2009 Location: wc Ohio Points: 1370 |
Tom , try this one,
TomYaz
[QUOTE=R Aiken]Tom , try this one,
[/QUOTE]
Not much there I didnt already know other than the soda to water ratio. My process DOES work, just having a high amp draw.
I disagree about the bubbling reaction will stop when rust is gone. I have had a small part in for 24 hours and still bubbling even though its all black.
CJohnS MI
Orange Level Joined: 27 Jun 2010 Location: Lapeer MI Points: 326 |
Lye is caustic on its own.
The electrolysis process works best when washing soda is the electrolyte. The greater the distance from electrode to workpiece, the greater the resistance, which will drop the amperage draw. When a part has given up all the crud, rust, paint, grease, etc, the bubbling drops off dramatically. Lye & electrolysis DOES NOT MIX. |
TomYaz
Mixed well for me...getting nicely cleaned up parts; paint falls off,rust turns blak.....so not sure what your getting at
Rawleigh
Orange Level Joined: 14 Sep 2009 Location: White Stone, VA Points: 421 |
Tom: Try putting a battery in line between the charger and the tank
TomYaz
If it comes to that I will try it. Thanks. I suspect my solution is just too strong...
Think I will go to washing soda anyway because I am getting a bit tired of the extra precaution required... But I wonder why the crud settles instead of floats...is it the lye?
CJohnS MI
Have never used lye. Typically, there's a floating crud layer, but all the big stuff ends up at the bottom. Some folks use a brick, or suspend the part so it doesn't touch the crap at the bottom. 100%, absolutely pure water is non-conductive. It's the other things that get into that change its resistance. |
MBolton
Bronze Level Joined: 03 Apr 2010 Location: Wisconsin Points: 35 |
Washing soda is soda ash is sodium carbonate is lye.
TomYaz
lye is sodium hydroxide, not sodium carbonate.
DREAM
Orange Level Joined: 06 Jan 2010 Location: Elberton,GA Points: 1828 |
Tom, if your welder is an AC machine, I don't think you can use it for that, and it could be very dangerous. DC is safer for this. Be careful.
TomYaz
Thanks Dream. Dont think I will be doing a welder anytime soon. I was able to get my amps under control, I think diluting the solution helped.
LouSWPA
Orange Level Access Joined: 11 Sep 2009 Location: Clinton, Pa Points: 24429 |
Just an FYI, AC will not work at all, the current must be one direction to accomplish anything
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
jjrosty
Silver Level Joined: 15 Sep 2009 Location: Broken Arrow OK Points: 106 |
I would check to make sure you didn't have a short.
Post Reply | |
