7020 Powershift
Eugene View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eugene Quote  Post ReplyReply Direct Link To This Post Topic: 7020 Powershift
    Posted: 28 Sep 2010 at 3:10am
Iam having trouble with the transmission brake on a powershift 7020. The inching valve appears to have full travell but you can't get  the range to go in at all without bad grinding.  What can go wrong ?
I am also having trouble with the adjustment of the cable. It is only a few years old, I can't seem to get the adjustment correct. I don't know if it is supposed to be like this, but when in neutral position the lever coming out of the valve appears to have lot of play in it. When you select any other gear the lever is locked in rigid.
It is a black belly with serial number 4024.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 8:06am
Probably a broken snap ring in the valve body.Part # 70932837.It's pretty small,costs like seventy cents,but you have to take the valve body off to replace it.You will need the gaskets #70268292,seal#70930484,O-ring#70923560 to do the job.Other things could be bad,but that is the most likely.
