Need help with D17 hydraulics
IVD17gal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IVD17gal Quote  Post ReplyReply Direct Link To This Post Topic: Need help with D17 hydraulics
    Posted: 27 Sep 2010 at 9:02pm
I have a Series IV D17. The other day I started it up and could hear a high pitched whistle that seemed to be coming from the hydraulics. Tonight we were going to try and figure out what was wrong, I moved the position control lever and the traction booster lever to see if it would make the noise stop, but now there is a loud grinding noise that doesn't stop. The position control lever is now very hard to move and doesn't seem to do anything. The rams are fully extended and will not go down at all.
Any thoughts?
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 9:09pm
If you hear a sucking sound coming from your wallet, you know it will be expensive.  LOL
How are tractor's fluid levels?
Post Options Post Options   Thanks (0) Thanks(0)   Quote IVD17gal Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 9:11pm
Fluids should be ok, but I can't properly check the hydraulic fluid because I can't collapse the rams.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IVD17gal Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 9:14pm
The noise its making now is the same one you would get if you were using the remotes and kept the lever engaged after the implements cylinder was fully extended or collapsed. Except it wont stop.
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 9:20pm
Sounds like the traction booster valve sticking..  -Wes
Post Options Post Options   Thanks (0) Thanks(0)   Quote IVD17gal Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 9:25pm
How do I fix it?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 9:42pm
Check that the traction booster linkage is not pushing against the valve on the underside of the console.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IVD17gal Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 9:49pm
There is a piece that sticks up between the traction booster linkage and the position control linkage that is against the valve.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 10:07pm
make sure the TB valve spool is not sticking either...
Post Options Post Options   Thanks (0) Thanks(0)   Quote IVD17gal Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 10:26pm
Your pic is what mine looks like. How do I un-stick it? I don't use the tractor to plow so I don't need the valve to work just to stop making the noise. Would the traction booster valve stop the 3point from going back down?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 10:37pm
The cap can be removed from the rear of the TB valve, see pic.
Squirt some penetrant on the stem and work it back and forth.  Might be a bit tedious to do, but if it's hung up, that's what needs to be done.
Again, like others have mentioned, make sure that all the linkages are free and not rusted tight or bound up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IVD17gal Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 10:46pm
Thanks, and the only lever that is hard to move is the position control lever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IVD17gal Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 10:49pm
Sorry, one more question. Take off the cap that the pic is pointing to or the one below it? Thanks for all your help. Grandpa didn't know what to do so I was at a loss.
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 7:40am
Yes it will.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 8:45am
...the one that the arrow is pointing to
Post Options Post Options   Thanks (0) Thanks(0)   Quote IVD17gal Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2010 at 9:43pm
Thanks everyone. Runs like a champ now.
