Pivot Speed ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Pivot Speed ??
    Posted: 09 May 2022 at 7:32pm
How fast can a pivot "walk" during planting/harvesting seasons to get out of the way of different activities ?
fjdrill View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote fjdrill Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2022 at 7:35pm
Depends on the length, make and drive
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2022 at 7:42pm
Fj are you saying it takes a little bit to get that center tower out of the way on a 1/2 miler, Even if it’s a zimmatic?
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2022 at 7:43pm
Best guess, 1/2 MPH ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2022 at 8:21pm
not hardly........... more like 8 ft per minute.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2022 at 8:22pm
That’s 44ft per minute at the end tower as it’s the only one running 100% and I have never timed one but divide that by 4 and you might be close to only the end tower movement
Put it like this if you need to move 1/4 mile unit 90 degrees plan on around 3 hours zimmy tall rubber
Edited by Kansas99 - 09 May 2022 at 8:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2022 at 8:48pm
one blocking your path?Wink
Edited by DiyDave - 09 May 2022 at 8:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2022 at 9:04pm
I will bet FreeGas's.. PIVOT ...moves a lot FASTER than that !!  Wink
Edited by steve(ill) - 09 May 2022 at 9:05pm
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2022 at 7:07pm
It's been about 10 years since I've been around an irrigation system but IIRC, it took an 1/8 mile pivot about 30 minutes to move 90 degrees.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2022 at 7:39pm
Thank you to the NON TTPP clan Clap !!
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 9:12am
Takes 12 to 16 hours to make a full turn at 90%.
This page was generated in 0.439 seconds.
