Does the ib have a parking brake? |
Post Reply ![]() |
KMAG ![]() Orange Level Access ![]() Joined: 26 May 2020 Location: Elizabethtown, Points: 680 |
![]() ![]() ![]() ![]() ![]() Posted: 07 May 2022 at 8:36pm |
My B tractor 1/2 came with swivel brackets that serve as parking brakes. However, these won't work on an ib. Did the ib have a parking brake feature?
Ted in NE-OH ![]() Orange Level ![]() ![]() Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
Yes, The IB has a hand lever that pusher the foot brakes forward.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88421 |
right side, up against the fender... LONG lever...
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3941 |
would that lever work on a c tractor ?
Thanks guys.
Hud, i looked and the lever off the IB will not work on a C or B... The IB has a 1/4 inch thick plate bolted to the final drive housing and pointing forward for the C-channel frame to mount to. The parking brake lever is mounted to that plate and pivots on a bolt about 4 inches below the 2 x 2 box section that the brake pedals mount to... This plate is not on the B or C... On the IB, the lever is connected to a return spring. Also has a cross plate and sets under the right brake pedal and pushes the pedal forward and you pull the lever back... here is a picture.. not real clear.
Post Reply ![]() |
