6080 Cab and A/C help needed |
Post Reply ![]() |
977.3Ford ![]() Bronze Level ![]() Joined: 04 Oct 2019 Location: Dayton, Ohio Points: 102 |
![]() ![]() ![]() ![]() ![]() Posted: 03 May 2022 at 10:09pm |
Just drug home a 6080/w cab, #2021, and has the external thrust bearing. Overall it seems to be a pretty solid unit, no real mechanical issues known. However the cab is pretty rough, and i plan on this being a hay tractor so a nice interior is a must. Most of the upholstery is gone but seems to be easy enough to replace. The challenge is going to be the glass and a/c compressor. This has a Koyker loader thats pretty tight to the side panel, and at some point the compressor was removed. My fear is with the loader on it might've been pretty close to the loader frame and caused issues. I put a Sanden kit on my 8050 which was quite a bit smaller than the original compressor, would this tractor be the same?
Also the top glass in the door was busted out and the windshield was cracked from a tree branch. Is the glass available for these through Agco or aftermarket, or am i going to have to track it down through a salvage yard or possibly have it cut by a local glass place? ![]() |
Jimmy
1982 8050 Powershift 1982 6080 1992 R52 Gleaner |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7513 |
Fehr makes a good cab kit. Regarding the glass, an autoglass shop can make it and install for you. The glass gets glued in - no rubber seals, so your hopes of getting one out in one piece from a wrecking yard are slim. Can't help you with the AC compressor, I do not have a loader on mine, but it doesn't look like it sticks out very much. Maybe an inch and a half from the shield?
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 803 |
AP AIR has a Sanden conversion Kit part # 900-001 need to get drier not in kit
Will a glass shop be able to make a new windshield? I can see the door glass being easy since its flat, but the windshield has a slight curve to it.
As for clearance for the compressor, theres about 2.75" from the side panel to the loader arm, and 3" from the edge of the compressor bracket to the loader arm. |
Jimmy
6080fwa ![]() Bronze Level ![]() Joined: 10 Apr 2018 Location: Alberta Points: 79 |
your windshield should be flat, use safety glass from a glass shop. the sanden compressor coversion hy-cap sells is excellent and a big improvement over stock. You will need to blow out your evaporator and condensor and evacuate the whole system and replace the orings with new ones, and check for any bad hoses, and a new receiver dryer.
d19d d19lp 175d 190d 190gxt 190dxt 200 6080 7000 8010 9150 9190
Post Reply ![]() |
