1939 pull type plow.
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Topic: 1939 pull type plow.
    Posted: 03 May 2022 at 12:11pm
Does any one have a diagram of the bottom side of the plow where the plow share  bolts on? I took mine off last  year  and  can't  remember  how it went on .Thanks.  I checked plow parts  section .Thanks Again.
Edited by 1947WC - 03 May 2022 at 12:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 6:23pm
What bottom series do you have? The attaching parts can be different between different series of bottoms. However most old style bottoms just have a hook that pulls the share in place a bolt to hold it to the frog.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 7:30pm
16 inch. 1 bottom Thanks  Paul B.
Edited by 1947WC - 03 May 2022 at 7:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 7:41pm
Size means nothing. Need a part number from some part of the bottom assembly or a good clear close up to identify what series bottom you have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 8:18pm
25 16 CR  GX  87  but wear does the trended end hook to. There is a piece broke off the furrow  wheel. Is that were  the threaded end bolts to?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 6:38am
That share number looks to be an aftermarket number instead of an Allis Chalmers part number. However I'm guessing you have a #25 series bottom. Even so there are 2 different assemblies. To get a correct answer the proper question is needed.
Edited by PaulB - 04 May 2022 at 6:46am
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 7:10am
LOLLOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2022 at 3:04pm
Thank you so much Paul B.
This page was generated in 0.289 seconds.
