Allis Chalmers ACC50k
BottleHauler84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BottleHauler84 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers ACC50k
    Posted: 02 May 2022 at 2:19pm
What's everyone recommend for Hydraulic oil in a mid 80s AC acc 50k forklift?
I'm redoing the entire Hydraulic system and flushing and re sealing everything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 1:18pm
Adam.... most older tractors used some type of 20 wt hydraulic oil... you can probably get something like ISO 46 at you local NAPA or possibly Farm Store... You would also be safe using a good quality UTF  ( Universal Tractor FLuid)... or Hydraulic/ Transmission FLuid found at Farm Stores.
Dont buy the CHEAPEST stuff like Hydraulic 303 oil... Get the one that says PREMIUM and lists a dozen specs for CASE/CAT/ ALLISON/ JD / etc on the back.
Edited by steve(ill) - 06 May 2022 at 1:20pm
mj1964 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mj1964 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2022 at 3:00pm
we used good old AW32 oil in our ACC-50-L
This page was generated in 0.146 seconds.
