B generator |
DaveWisc.
Topic: B generatorPosted: 01 May 2022 at 3:28pm |
How do I polarize my generator on model B with 6 volt battery and positive ground
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90965 |
Posted: 01 May 2022 at 4:48pm |
The generator has two terminal .. Field and Armature "F" and "A"... the "F" is basically the ground ( thru the light switch... So you take a jumper and touch a the HOT terminal of the battery (negative) to the "A" terminal on the generator.. to get a spark ( 1 second).... Note that the BATTERY terminal might go to the amp meter, then out to the CUTOUT switch on the generator... If it is still that way, then you can touch the jumper from the INPUT to the CUTOUT to the OUTPUT or "A" wire.
DaveWisc.
Posted: 01 May 2022 at 5:27pm |
Ok thanks it does have a cut out on the generator and not a voltage regulator
DaveWisc.
Posted: 01 May 2022 at 5:29pm |
Ok does tractor need to be running or not
Les Kerf
Posted: 02 May 2022 at 4:59am |
NOT running. |
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2720 |
Posted: 02 May 2022 at 12:25pm |
Not meaning to highjack this thread but what if you have a regulator and not a cutout? 6v positive ground.
steve(ill)
Posted: 02 May 2022 at 12:47pm |
same procedure... You can touch the BAT terminal of the regulator to the G terminal of the reg which goes to the A terminal of the generator..
All you are doing is TELLING the GENERATOR that the "A terminal is to charge to PLUS or MINUS on the battery.
mdm1
Posted: 02 May 2022 at 4:19pm |
Thank you! The way I remember is Boy(B) to Girl(G) but never to Female(F). Read that somewhere.
