Ac B front wheel bolts
gmk5150 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gmk5150 Quote  Post ReplyReply Direct Link To This Post Topic: Ac B front wheel bolts
    Posted: 18 Apr 2022 at 1:12pm
1938 AC
Im in need of front wheel studs there square headed
Anyone help where i can purchase ty Ray 763 286 2335
BigMo(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigMo(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 11:35am
They used to be available through millertire.com, I purchased a set a few years back. I’m not sure if they still have them.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 12:04pm
Do you have the 5 bolt wheels that bolt to the hub or the ones with the separate rim?
The 5 bolt did not have studs. It had lug bolts the threaded into the hub. The other had 8 rim clamp bolts that held the rim to the center. 1938's had either.
This page was generated in 0.116 seconds.
