ISOTrack pin tool
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: ISOTrack pin tool
    Posted: 15 Apr 2022 at 10:40pm
Master pin can be driven out with a BFH by using a pin held against the master link .
Next problem is if you need to remove one link of which end do you remove - as you will need to remove another link .
  That link removal will change the overall dimension of the track and the on-center measurement between links - WHICH MEANS - the SPROCKET PITCH to BUSHING On-center will be off and lead to wear on both sprocket and track .
  Check the track to see if it has been turned in past - if not then have it pressed and turned at a track shop - to bring it back to close to acceptable specifications .
  OR CUT OUT 1 Link and ruin the ability to turn it later along with putting stress or rear case and bearings and damaging them beyond salvage later
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2022 at 7:03pm
YEP... chain is stretched so it does not fit the sprocket... Removing a link does not fix the problem... might make it worse with a snug chain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2022 at 6:16pm
If you are shortening a track, then the UC is already fubar, and now you are gonna tear up the sprockets, too!  JMHO.  Someone should be along to talk about the tool...Wink
yzfarmgirl28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yzfarmgirl28 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2022 at 1:53pm
Looking for anyone that is knowledgeable about track pin removal. Need to remove/shorten a H3 track. Any information or expertise advise appreciated.
Would purchase or rent any type of pin press available.
Thanks
