What years B/C pto had no hydraulic pump mount. |
KMAG
Joined: 26 May 2020 Location: Elizabethtown, Points: 690 |
Topic: What years B/C pto had no hydraulic pump mount.Posted: 10 Apr 2022 at 6:48pm |
I was looking at a Frankenstein B today (assembled from many dead B tractors). It had a driver's side belt pulley pto, but no opening/mount on passenger side to accept a hydraulic pump.
What year B's had pto w/o hydraulic pump mount? |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90994 |
Posted: 10 Apr 2022 at 8:46pm |
Personally i have never seen a "B" without a least a cover plate where the pump mounts.... But you have to remember a "B" was originally designed to replace a horse and the GOAL was to PULL an implement... not much lift needed.
The EARLIEST "B" i have is a 1941. Edited by steve(ill) - 10 Apr 2022 at 8:50pm |
ZachD89
Joined: 24 Dec 2015 Location: Littlestown,PA Points: 703 |
Posted: 10 Apr 2022 at 8:59pm |
My 1937 B and 1939 B have no place for a hydraulic pump
37 A,37 Waukesha B,35 WC,38 WF,M crawler,49 WF,49 WD,53 WD45,39 and 40 RC,47 WC,41 B,39 B,48G,48,C,59D10,D21,IB,B10,B12,B208,B1,Roto Bale Loader, sp100 combine, allcrop 66, L3 Gleaner
Wispitfiremike
Joined: 28 Mar 2017 Location: Milwaukee, WI Points: 210 |
Posted: 10 Apr 2022 at 10:08pm |
My 38 does not have one but my 1940 has a pump on it, now could it have been added later? Yes, entirely possible as most of these have changed hands several times since new.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55324 |
Posted: 11 Apr 2022 at 4:27am |
The answer is that as things improve, they change, so the early b's may have no provision for the pump, but as design is fluid and changing, later tractors will have the pump mount and the PTO. Look at the serial number, in front of the shifter, look it up, and trace the number to find the year.
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 11 Apr 2022 at 10:05am |
Of course the original B tractors did not have the hydraulic pump. However, they did have provisions for a PTO. The original PTO's did not repeat did not have the configuration to add a hydraulic pump. You may have seen some very old PTO's that did not have the side opening for a hydraulic pump.
That said, any B tractor could have a hydraulic pump added. You would just get an up to date PTO configured with the hydraulic pump plate and add the hydraulics. Therefore, any B tractor could have a hydraulic pump added. Remember, the PTO and the hydraulic pump was an add on. In fact when we sold them there were very few B's that did not have a hydraulic pump. Good Luck! Bill Long
Dakota Dave
Posted: 11 Apr 2022 at 2:34pm |
When I got my C in86 it didn't have a PTO the old allis dealer had several no hyd pump PTOs in the back but none with hyd pump they they wear removed to add a pump to early. B's
Edited by Dakota Dave - 11 Apr 2022 at 2:35pm |
