190xt power director pressure |
Post Reply ![]() |
Page 12> |
John m ![]() Silver Level ![]() Joined: 11 Apr 2020 Location: Wetmore, Mi Points: 278 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Apr 2022 at 1:05pm |
I think this sucks but. Replaced all torque housing gears, visual check of power director plates and clutches, replaced clutch hub, replaced clutch hub sealing rings. I have checked the power director linkage, everything is tight not bad bushings or anything. It is giving full stroke to actuating valve. I hooked up pressure gauge to the Allan head test ports. I am only getting 11 bars (159.5 lbs) of pressure. Drops to 2 bars (29 lbs) of pressure in neutral. If I leave the clutch out with transmission in gear I would stall the tractor out even with power director in neutral. I did rebuild the hydraulic pump, the three point and power steering work as it should. Pto works great, it is a hydraulic pto. I'm really hoping I don't have to split this tractor again. Anybody got ideas, I got my fingers crossed. And the hydraulic oil is to full mark. Thanks, John m
Edited by John m - 10 Apr 2022 at 1:08pm |
Ky.Allis ![]() Orange Level ![]() ![]() Joined: 31 Jan 2010 Location: Kentucky Points: 1034 |
Well I'm certainly no mechanic but I'm guessing the problem is the PD valve is sticking. My 200 acted similar and after removing the valve and dissembling it and a good cleaning and light honing it worked perfect. I was amazed at how much crud had built up in it.
Thanks, sure hope that's the problem. I was just sitting here looking at it. Guess I'll pull that apart and look at it. Thanks again, John m
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
Sounds like a plate is not splined on a hub or gears in PD are not matched.
If I read your post right, it killer's the engine when you let foot clutch out no matter what posion gearshift or PD is in. Right? MACK
When in reverse the tractor moves rearward or when in a forward gear tractor moves forward. There is no neutral no matter which position the power director is put in. If the gear shift is placed in neutral then there is no movement when clutch is left out. It's like the power director just stays locked up. I checked the pressure at the Allen head test ports and I only have around 150 lbs. in high or low. About 20 or 30 lbs in neutral. I was going to try and pressure check the actuator at the input line and see if I even have more than 150 lbs coming from the pump. Sorry if my explanation is confusing. Thanks, John
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8367 |
Your pressures are way to low- and there is something internal going on - there has to be 0 to 30lbs of oil pressure in the Powerdirector neutral
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22058 |
Did you actually disassemble the P.D. clutch ?? How did it work before you took the tractor apart ??
It worked good before. Just put a new housing in that the three sealing rings ride in and the new sealing rings. The plates/ clutches snapped back and forth when I checked it with air pressure. Think I need to check the pump pressure and be sure I have enough pump pressure. Then work towards the power director to start eliminating where I'm losing or lacking pressure at. Good power steering and three point works. Got me baffled. Never disassembled the PD Thanks, John
Edited by John m - 11 Apr 2022 at 4:24pm |
But, low pressure has nothing to do with serious creeping, if I'm understanding the complaint correctly. All low pressure would cause is slipping under a load.
So your saying the clutches in pd are stuck? Either in low or high? I guess I am associating the low pressure would lock one side of the clutches either high side or low side. Wonder if I should take it for short ride and attempt shifting it? I've only let it go a foot in either direction cause it's in the garage yet.
I wouldnt do nothing till you get the pressure up !
Start it up. Leave P.D. lever in neutral. Set both brakes hard. Place transmission in road gear. Let out the clutch. Engine will labor some from "creeping" which is normal to a degree. If it kills the engine you have problems. Again, low pressure ain't causing this.
Ok Doc, I'll try that next and see what's happening. Thanks
How does the power steering work??
I just went out to the garage and put the power director in neutral, put it in high gear with a little throttle, I left the clutch out. I held both brakes and the engine bogged down a little and kept running with clutch out.
Powering steering works great. One finger turns
Pull side cover and look at PD. Plates should be evenly spaced apart. If not, you have some warped divider or broke plates.
Any time a PD is out is a good time to take it apart and check it out and reseal it. Sounds like broken plates piling on top of each other. Resealing might take care of your low pressure. MACK
What do you mean by reseal? I did put the three sealing rings in and new housing that bolts to trans for pd. Are you referring to the seals inside the pd? Thanks, John
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8652 |
Have no experience with that model but with hyd clutch packs there has to be piston seals in the pack. I am suprised you didn't think to go there. I know,it was working fine...BUT YOU WERE THERE!!! Seals get old and hard over time. Wonder how long they have been there? For future reference,any time your that far in you do clutch seals period. 7 & 8000 series PD tractors the same. If it's split you pull the PD out and reseal unless you know when they were done Last. Can save some clutch parts because it won't be slipping/heat/warping plates. Only my opinion/experience.
Four piston ring seals plus two orings. MACK
Thanks Mack. Ive been reading through old posts half the night and I think I may be on to the problem. I think I may have damaged the pd when aligning the torque housing and transmission. I had to keep turning the pd and input shaft to get it together and remember it was a bugger to get together. I read one post about three in the morning where someone damaged theirs that way. I'm leaning towards splitting it again and see if that's what happened. Wish there was another way to be sure but I don't know of one. PD worked great before I exploded all the gears in housing.
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2415 |
I think that if you pull the plate back off of the side,you will see that the clutch plates aren't free to move around. Use air to test the movement of the pistons.
Piston stroke should be equal for low and high side when air checking.
Taking plate and valve off now. I'll check with air and report what's happening. Thanks
Doc Mack. I removed valve and plate from right side to look at pd. The front portion I can move the tab ends of plates with my finger. The rear tabs feel tight and the springs appear collapsed. I spun the director and checked it all around and it appears that way all around. I put the rubber tipped air nozzle on both small tubes and gave it air. Air is coming out of the divider both at the very front portion by the plates and at the rear portion by the plates. The front portion does move with air, the back portion moves very little. I know by using my finger the front set of discs are definitely loser than the rear. Sorry if I'm confusing with my explanations. John m
Edited by John m - 12 Apr 2022 at 9:56am |
And I can see no broken or over lapping plates or discs.
But, you have an internal problem. The free movement of the separator plates on the front (low) section is the way it should be. Warped or broken plates/discs will make things like they are in the rear (high) section. This is what's causing the excessive drag. Maybe caused by low pressure from before, which will allow slipping under a load.
Thanks Doc. Looks and sounds like I'll be splitting it again. Kinda weird though when I had pd out and on the floor I put air to both fittings and there was no air leak. Both sides just snapped back and forth. I thought maybe I had something in a bind. Oh well, guess I better get to work. Thanks, John m
Replace all the hi side plates from 7000 plates. Don't have # but can get it later or Dr. has it in his head. MACK
Thanks Mack, I've seen some of his posts saying that's what should be used. I'll definitely go that route. I'll probably have it apart tomorrow. Got everything ready so all that's left is pull the bolts and split her. Thanks again, John m
Post Reply ![]() |
Page 12> |
