flux for soldering,,,,,,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: flux for soldering,,,,,,
    Posted: 06 Apr 2022 at 6:29pm
 I think a few weeks ago,,I was singing the praises of this "Water Soluble Flux" made by Harris,,, THe little .5 oz tube was included in the soldering gun kit I got at Lowes and It absolutely made me a believer of soldering wires together,,,!!  I been soldering a lot lately making up the wiring harness of those winch controllers and I HAVE RAN OUT of the flux,,,,!!  The bad part is I cannot find any anywhere!! I finally called Harris Mfg Co and talked to their CS Dept and while they admit they do still make it,,,they ONLY sell to distributors,,! I aslked for a list of their ddistributors and one is Fastenal, Plains Welding which are within 100 miles but,,,they do not stock it and were not too interested in ordering some for me, even tho I gave em the address and phone for the Harris Company. I told the dude at Plains Welding I would order $20 worth if he would get me some,,,,??He said he would try tamarrow,,,,(It was 1Pm)
What is it with these workers??
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2022 at 8:06pm
I have never used flux soldering wires together, just rosin core solder.  Now I have used plenty of Harris flux on copper fittings, got it at United Refrigeration Supply but I would think maybe an electrical supply company or maybe Johnstone Supply.  I've also been very happy with Nokorode products.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2022 at 8:23pm
Yup, rosin core solder is all you need. The old lead-based type works much better (I am hoarding my stash)
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2022 at 8:36pm
Rosin core for clean wire, acid core for dirty nasty corroded wire.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 6:47am
never use 'acid core' (aka plumbers solder) for soldering wires ! The acid is a 'gift that keeps on giving' and will destroy the wire over time
Rosin core... 2 types.. old(smell great..) new ( water soluble)
If you have 'dirty, nasty corroded wire' GET RID OF IT !! The corrosion is inside and will 'wick' it's way to the other end. Grab a piece, strip off a bit...if not clean cooper, strip more. I've had 150' of it go 'funny' once.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 6:51am
That's what I was a-thinkin' Jay!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 6:57am
heck,I've only done soldering for 6 decades, what would I know ?Smile
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 7:11am
Acid-core flux never stops working... it does everything water does to copper, and more.  Reserve it for fitting plumbing, go rosin core on electrical wire.
The other reason to be wary of dirty-corroded, is because stranded wire is highly disposed to capillary action... it draws water up the wire with wonderful effect, and once the moisture and minerals in that water start reacting with copper, the wire strands assume a fuzzy-green personality, and they'll seemingly always do it right-in-the-middle of a wire somewhere... so the really good connections one puts on an old dirty wire look great, but the middle of that wire is nothing more than a plastic-covered resistor.
Applying rosin-core solder to a crimp terminal, however, does a very good job of filling in the filaments of that wire, and while the insulation is still slightly soft, pull it up against the solder of the terminal, and you'll have an effective seal for the strands beyond.  Top it off with a little heat-shrink, and some proper securing, and you'll have a wire that lasts a LONG time.
Water-rinse solder fluxes were developed back in the late '80s when 'wave soldering' of printed circuits was perfected.
Darned near any type of electrical solder flux you can imagine, is on the list at Digi-Key, probably Mouser too.  Grainger will have SOME types...
Kester sells it in a handy 'pen' applicator... The Flux Pen 186 is a favorite of mine.
Edited by DaveKamp - 07 Apr 2022 at 7:16am
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 7:21am
DJ, did you give google a try?  I got a hit on it, but was in a plastic jar, not a tube.
Just stumbled across that stuff on Face Book.  Source listed was SupplyHouse.com.
Edited by Dave H - 07 Apr 2022 at 10:02am
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 11:35am
Wink Dang old bunch bubble poppers.   Being cheap I save ever little piece of copper wire. Cry Thinking just take a little more insulation off and use it again. Ouch But this could explain Confused why my old junk wont go. Ouch
 I did find a battery cable that had a rotted spot 6 inches inside the insulation on a tractor that gave starting trouble at times. Wink But I just figured that's how JD tractors where...............Shameless said.  An the fact I bought it from a guy known as Hammer Head in the neighborhood, after he overhauled it.LOLLOLLOL
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 11:55am
  try Amazon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 12:29pm
I always wipe a little rosin flux on the wires before i solder... Been doing it that way for over 50 years.. Too old to change now.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 4:19pm
Dang!... Never paid much attention to that fact.
 Never had a trouble in having to track down a bad wire connection that I solderd.
 Went and looked, Soldering paste flux, alphametals -  contains zinc Chloride...
 and the solder wire itself, one spool says acid core, another doesn't say anything, another says lead free ASTM B32, another said for electronics, that was very fine solder wire...
  Now I got to remember to watch out for the acid solder when soldering stranded wire, such as even battery cables when I solder them and then crimp them while hot.
  I went to soldering everything that should not need to be disconnected and paint them in liquid insulation that dries, or slip shrink wraps on them.
  Those old 3m quick connects, they will eventually fail for sure from corrosion that gets in over time. Hate them for that fact.
 Never heard of the water soluble flux. Learned some new things today.
Ken Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken Mn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 5:03pm
I use Oatey Water Soluble Tinning Flux on most everything I solder. There are other brands as well available from hardware stores or anywhere plumbing supplies are sold. It is made for soldering copper water pipe so it is lead free. Tinning flux is gray in color because it is powdered solder mixed with a water soluble flux. Work very well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 9:48pm
 Well,,I used to have some success with acid core solder,,but not all the time,,,,,
 With rosin core,,,I NEVER HAD ANY lUCK weirth a CHIT,,,, That's why I was so excited bout the ease of soldering by using the Harris Water Soluble Flux,,,!!!  I mean that stuff would suck the melting solder right into the wire and make the prettiest job,,,!!! I mean I used to would literally shy away from soldering anything and even started to use the crimp on ends to keep from using any solder,,,!!! THis stuff is THAT GOOD!!!!!
 Hey Dave H,,I'm gonna check out that link you posted,,,,Clap
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2022 at 8:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2022 at 8:05am
I was an Avionics tech in the Marines back in the 70's, then spent 30 years in sawmill maintenance (saw filer), then went back to school and got my degree in Bio-Medical technology, and ended up my career in the Engineering department at an encoder manufacturing company (it paid well and was close to home). https://www.encoder.com/
I am pretty good at soldering, but not good enough to keep up with the girls that do the soldering inside those little encoders on the production lines Tongue They not only solder well but they also solder quickly.
We had to be able to pass the J-Standard soldering test: https://www.protoexpress.com/blog/ipc-j-std-001-standard-soldering-requirements/
It is mighty difficult to accomplish this with anything but brand-new, spotlessly clean components.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2022 at 8:57am
 Well,,,we getting closer and closer,,,ole WF Owner has fount what I'm looking for,!!!!,,Home depot lists a "Solder Kit" for a measly $6.95 that includes a small roll of solder AND,,,AND,,a tube of the Harris Water Soluble Flux stuff I want,,!!!! Only'ist thing they dont carry it but can be ordered thru them ,,,minimum order is $45 Plus S&H,,,,,I'ma call my lady friend at the Alien Town store and she if she can help me get around that and order bout 4 kits which ought to last me forever,,,,
 Ya'll that do soldering,,,auta try this stuff,,,it IS good,,,!!
DavidKT Ky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidKT Ky Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2022 at 3:52pm
If you are still looking there is a listing on ebay item 284749704055 .
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2022 at 2:18pm
  Well,,,ole WF Owner,,,come thru,,He Did,,,!!  I called my lady friend at Home Dept in the Alien Town,,,and lordy, lordy,,,they had 3 KITS on the shelf,,,!!  WHAT?? When I talked to CS at  Harris Company ,,they "DID NOT" list Home Depot as one of their distributors,,,!!! What the heck,,,?? Anyway, as we speak,, my son is going to The Alien Town and he will pick up the 3 kits for me,,,,,  Ain't that the CHITS,,,when you look all over the frigging world and the dang stuff is hid out almost under your feets,,,,,
  OK,,I feel much better now,,,,,LOLLOL
 This Is the absolutey the BEST bunch of " SEARCHERS"  ever to come together,,cause they can find ANYTHING any of us needs,,,,and prolly some we do not want to find,,,,WinkWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2022 at 2:38pm
Glad you got what you were looking for! It was just luck that I found it.
