49 wd charging or not
briangroc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote briangroc Quote  Post ReplyReply Direct Link To This Post Topic: 49 wd charging or not
    Posted: 26 Sep 2010 at 3:02pm
ok 49 wd wired up per dueys diagram. negative ground (i think, thats how it was when i got the tractor but im not sure if it ever really was working that way). . not sure how to tell either.
it has a mag, not a dist.
when i run tractor, ammeter pegs to negative side of ammeter.
i reversed the wiring on the ammeter, and it read nothing
lights dont work. but key turns off tractor now.
not worried about the lights im just tired of jump starting the tractor.
your guys knowledge would be very much appreciated.
thanks ,  brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 7:01pm
What are you using a generator or alternator? If genny is it 6 volt with cut out relay or do you have a regulator? If you crossed the ground hook up from what it was( with generator) you may have let the smoke out of the genny.
Post Options Post Options   Thanks (0) Thanks(0)   Quote briangroc Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 10:26pm
alternator with internal regulator, if i have it hooked up backward could it still be charging but read negative?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 10:31pm
if you connect an alternator up backward (+ ground), it will blow out the regulator and no longer work... You need a negative ground on almost all alternators. If the amp gauge reads backward, you reverse the leads on the gauge... but alternator big terminal is + and battery negative is ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 10:38pm
The amp meter was originally set up for positive ground so with a neg ground alternator it would read backwards. My WD45 has been that way since I put the alternator on it 10 or so years ago. If you wired it backwards and the amp meter had already been switched the alternator may be smoked.
 Check voltage at you battery with the engine off, and then with it running. You should have 12 not running and at least 13.5 running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 10:39pm
If you have a 10SI alternator , there is a hole on the back (looks like a upside-down U) mouse hole .. just inside the alt is a tab that sticks up off regulator board. If you use a small metal probe or a screw driver to ground that tab against alternator case it grounds regulator to full output.
 If everything else is working, (brushes and diode trio ) you should get full output.
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (0) Thanks(0)   Quote briangroc Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 2:13am
i have the part numbers duey has on his site., i have a mag. battery is negative ground. so i am assuming ammeter reading negative would be charging? I think...
guys thanks for all your input, much appreciated.
