B110 Differential
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: B110 Differential
    Posted: 02 Apr 2022 at 8:23pm
A few months ago, I took the differential off so that I could replace the axle seals.  Finally got around to putting things back together.  Can someone tell me if I have the gear in the right way, and do I have things in the right order.  According the the manual, 2 washers go on first, then the 2 keys, then the gear (does not show which way), then snap ring and another washer before the differential gears.  If assembled this way, there will be a space between the gear and the snap ring - that does not seem right.
I hope someone can shed some light if I am on the right track.
Many thanks!
oldfords View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldfords Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 10:51am
As I remember working on these, the gear goes the other way. If you install it the way you show, the differential will not be able to slip when you turn corners.
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2022 at 10:27pm
As Oldford's said, the teeth of the gear go towards the hub.
This page was generated in 0.107 seconds.
