Ball Hitch Planter .... |
| Author | |||
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Topic: Ball Hitch Planter ....Posted: 01 Apr 2022 at 6:46pm |
Guy that pulled a planter with a ball hitch system on his planter/tractor ?? What's his "forum name" and where's he been ??
| Sponsored Links | |||
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Posted: 01 Apr 2022 at 7:10pm |
If I’m not mistaken didn’t John Deere have a few models years ago with that?
FREEDGUY
Posted: 01 Apr 2022 at 7:21pm |
This guy was/is a member on here and NAT, seems like he worked for the Ford tractor plant on the P/S tranny and then ended up at JD on the same project?? He did the ball hitch on his own in the early '80's ?? Thanksfor the reply
Edited by FREEDGUY - 01 Apr 2022 at 7:22pm |
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2337 |
Posted: 01 Apr 2022 at 8:15pm |
Old JD 490 planters had a ball hitch, also 494 planters.
Lars(wi)
Posted: 01 Apr 2022 at 9:07pm |
If I recall, didn’t those planters have a chain/cable on each side of the hitch, and those activated the row markers, when you turned around at the end of the field? |
200Tom1
Posted: 02 Apr 2022 at 12:32am |
Dad bought a 490 planter in 1962. It had a pin dropped in the drawbar. The pin had a loop on the top of it and another pin went through a couple of loops on the cast iron planter hitch and went through the loop on top of the pin. That pin was held in with a cotter key, nail bent over, or a clip if you could find it. My 494A was the same way.
jiminnd
Posted: 02 Apr 2022 at 11:54am |
Yes, they controlled the markers with a chain, some of the time, if were adjusted just right it worked.
plummerscarin
Posted: 02 Apr 2022 at 12:45pm |
Have 2 494s. Both pin hitch. A small pin that drops between two lugs and some kind lock through the lug holes. Marker control chains attach to a slingshot type frame bolted the drawbar ahead of the hitch.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55276 |
Posted: 02 Apr 2022 at 6:07pm |
Ball hitch, that just sounds painful, ooch eech!
FREEDGUY
Posted: 02 Apr 2022 at 6:29pm |
Sadly, I'm going to call BS on your reply, We ran a 294 A and there was NO provisions for a "ball hitch" ![]() !! Oddly, the 494 "elongated" hitch pin area is EXCATLY the same elongated hitch on the '86 7000 CT![]() !!Yet "AGAIN" , you guys are missing the point of my post, Who's the guy that has NOT replied on here or other forums recently ?? Seems like he was from Iowa and had at LEAST TTPP but was very cordial with his info
FREEDGUY
Posted: 02 Apr 2022 at 6:35pm |
YES !!! It was a "U" bracket that bolted to an unused hole in the drawbar of the WD/D 15
![]() !!! It was a "chain" that was involved ![]() !! Man, that brings back AWESOME memories ![]() !!! |
FREEDGUY
Posted: 02 Apr 2022 at 6:38pm |
[QUOTE=DiyDave]Ball hitch, that just sounds painful, ooch eech!
[/QUOTEIs it "momma" or Trump getting you the "OUCHY" ???
DiyDave
Posted: 02 Apr 2022 at 7:15pm |
Lars(wi)
Posted: 02 Apr 2022 at 7:16pm |
Worked for a neighbor that pulled with a Farmall 656 gas, the first year I worked there, then traded if for. JD 7000 4row. Planted 700 acres a year, it was for whole 8 years I worked for them. Then went and worked for another neighbor, he had the same planter, pulled with a JI Case 830D Comfort King. |
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4873 |
Posted: 02 Apr 2022 at 7:37pm |
The only farm equipment I have seen with ball hitches is hay balers. Thought it was a pain to have to deal with until I used it. Pulling a 3 wire tie baler with it's own engine on it with a JD A. The ball hitch took a lot of the jerk out of that big plunger hitting by not having baler rattling around on a 3/4 pin in a 1 1/4 hole.
jiminnd
Posted: 03 Apr 2022 at 11:24am |
Guess I have to confess I forgot, yes it was a separate attachment for marker control, just didn't remember, planter been gone for 40 years and my memory isn't getting any better.
FREEDGUY
Posted: 05 Apr 2022 at 8:05pm |
Seems like his name was Gerald ?? That was my OQ, what was his name and is he still around ?? Thanks
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90806 |
Posted: 05 Apr 2022 at 8:22pm |
been gone for a while...........
FREEDGUY
Posted: 05 Apr 2022 at 8:27pm |
Thanks Steve, I hope its' just a "snafu" that he's not been on here (Gerald J) .
Jordan(OH)
Joined: 11 Sep 2009 Location: Celina, OH Points: 1580 |
Posted: 06 Apr 2022 at 7:40pm |
He’s dead.
And you are totally wrong (as usual) about him working on the PS trans. |
FREEDGUY
Posted: 07 Apr 2022 at 5:57pm |
Well, thanks for the "death" notification (when was this ??), but are you certain about the PS tranny's ? In hindsight, you're probably correct, Gerald was an electrical guru if memory serves
![]() Edited by FREEDGUY - 07 Apr 2022 at 5:59pm |
Jordan(OH)
Posted: 07 Apr 2022 at 8:52pm |
Google Harold Brock
FREEDGUY
Posted: 09 Apr 2022 at 8:07pm |
Thanks Jordon, but I draw-the-line at "googling" people's names
, I won't stoop to it .
Lars(wi)
Posted: 09 Apr 2022 at 8:10pm |
Google isn’t the only search engine there is. I don’t use google. And I have no trouble finding information. |
FREEDGUY
Posted: 09 Apr 2022 at 8:19pm |
IMO, it's still "snooping"
Lars(wi)
Posted: 09 Apr 2022 at 8:43pm |
Just log on to the website of the local newspaper where someone lived, pull up the obituaries and search for the persons name. The family pays to have obituaries printed and posted on line, or in the newspaper.
Ray54
Posted: 10 Apr 2022 at 4:27pm |
This is not snooping???But we now know his name is Harold Brock and to look up what is on the world wide web is snooping??? Like maybe reading his obituary, which in general praising the good things the person has done, would be snooping?
So I guess you are looking for gossip??? |
