Aluminum welding,,,,?
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: Aluminum welding,,,,?
    Posted: 29 Mar 2022 at 7:01pm
 I had been seeing them commercials on doing some aluminum welding with that special weld rod that Harbor Freight sells,,,so I thought ,,,What The Heck,,,and bought a pkg of i think,,6 rods bout 14" long. I had a Pierce 12,000 Winch that a friend had given me 2 years ago and it had one of the end plates had a chunk broke off and the other end had also  cracked. I took the pieces to 2 welders in town and they both wanted OVER $250 to repair and I figured I would try the HF rod once and if it did not work,,I would bite the bullet and have a real welder do the repairs.....Wink
 I Watched a couple of videos and biggest issue is to get the parent metal up to 725° BEFORE you apply the rod to the parent metal and let the parent metal melt the rod and use the rod to "move" the liquid aluminum as you add more aluminum to the puddle. After a couple of tries on a piece of junk aluminum,,,I took a slug of Jack Daniels and fired the torch up,,,,,LOL One of the videos had them using them small green propane bottles for heat source but I never could get it hot enough so I used my Propane/ Oxy torch ,,,,Clap I will tell you WHAT,,,,that stuff works slicker than owl chit,,I was amazed !! The literature even says you can use this rod on pot metal,,,Pot metal, even dis=similar metals,,, It really works great,,!!!Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 3:14am
i'm proud of ya son!
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 9:21am
Now Joe, I'm a bit confused and wonderin.  Was it the welding rod or the slug of Jack Daniels that worked slicker than Owl Chit........
D17 Series 1
Allis B- 1939
Allis B- 1945
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 11:11am
  Well,,Scottie,,,I couldn't rightfully say,,,,,,I tripped over an empty bottle of something when on my way into the house,,,,,,,,LOLLOL
 Actually ,,I ain't had a drink since my Cardiologist gave me two choices bout 25 years ago,,,,,,He told me "You can keep on drinkin like you do and figure on NOT makin it past 60,,,or you can throw away all them "hid-out" bottles of JD and maybe make is past more years,,,,,,, SO,,, I took those I knew of and went and buried them by the back fence,,,you know...in case they run out or someone starts a war and we need some antiseptic,,,,,,,,,,LOL,LOL
 PS,,that weld rod is best I've ever tried,,,!!!!
Edited by desertjoe - 30 Mar 2022 at 11:12am
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 12:42pm
Joe, is it actually welding, or is it more like brazing or soldering?
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 1:14pm
 Aw Chit,,,you caught me ,,,Lou,,,,!!  You sure did,,LOL
 Naw,,I wasn't trying to fool no one,,just sometimes my mouth don't say what my brain is thinking,,,,annd my typing fingers don't pay no attention to either of them,,,,,LOLLOL
 Yes,,it is just soldering and it is the best'est I've ever seen and biggest issue is getting the parent metal hot enough (725°) If you try to melt the aluminum rod onto the weld,,and the parent metal ain't hot enough,,the rod just runs off your work and makes a mess. I went back to HF and bought another two bunches,,,you know,,,to make sure I gots some IF I need to,,,,,LOL
 Fact is,,I'ma gonna try to "weld" some pot metal,,,brochure says it will,,,!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 6:13pm
hey Brudder, I didn't catch ya, I was just curious.....and, uh, I get what you mean having trouble with the brain and the mouth, or brain and fingers communicating!
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2022 at 3:36am
WELL,,,,,,,,,,,the brain,,,,,,,,,,,,,doesn't communicate....it only THINKS it can.  The mouth is like a fine watch,,,it runs just fine.  Now the fingers.....well we won't get into that on here,,,,,SO.....
Can you "weld" "solder" "braze" them ole lawn chairs with the stuff??
Do you HAFTA us JD with it?  Is that for a cooling effect??  Or is it a flux??  Hehehe.....
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2022 at 6:56am
That’s good to know, I’ve watched some videos by Muggy Weld but didn’t want to go through the hassle of ordering the stuff and of course the lot size is 20 times more than I want, especially if it doesn’t work.  Next time I’m in HF I’ll pick some up.
