Towing A SD Dually ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Towing A SD Dually ??
    Posted: 28 Mar 2022 at 6:16pm
Why would an '05 vintage 2x4 dually need to have "one" of the outer rear wheels removed to have a "lift-type" wrecker hook-up and tow it ?? This is from my Ford OM Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 7:05pm
So the tow truck guy could charge moreBig smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 7:16pm
In other words, you're clueless Sleepy
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 7:22pm
Your the one asking,, now who's clueless?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 7:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 7:35pm
So Re Read that Section of the Manual, that is for FLATBED ROLLBACK Towing where with ONE Wheel Removed the truck will sit within the dimensions and side rails of that Roll Back Bed.  NOT for FLAT tow or Lifted by Chains Tow.
Edited by DMiller - 28 Mar 2022 at 7:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 7:38pm
LOL LOL  Thumbs Up
well it is obviously TOO WIDE for his lift arms / brackets... They are adjustable in and out for small cars up to bigger pickups.. But the DUALLY is obviously too wide with all 4 wheels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 7:40pm
Methinks gassy is worried about getting repoed...Wink
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 7:47pm
And here I was going to convince him he had all his beer loaded on one side of the box so the tow truck operator was taking the outside tire & wheel off to balance the load.
bemer848 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bemer848 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 8:10pm
That is why he drives his dad's truck. His cheap truck broke down and he needs his beer run.WackoWacko
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 5:06pm
Well MR. D, I did in fact "re-read" the OM , before I make any insinuations against your reply, WHAT do you consider a "WHEEL LIFT " tow ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 5:10pm
LOL LOL  Thumbs Up
Why it an "OUTER REAR" removal ?? Isn't the "inner" wheelbase the same as a NON DUALLY ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 6:37pm
Well now, since you EDITED the OP as to TYPE of Wrecker there is answers.  YOU stated lift type, there are SEVERAL of that style INCLUDING a Wheel Lift which requires NOT JUST One but Both outer rims of a Dually Removed as the Lift Saddles are designed but for ONE tire.  Is also a Chassis Lift or one that can lift by the Axle alone.  So once YOU corrected your misrepresented statement then the Correct Answers can be given.
Closer to that MAGIC TTP point?  Not really as will remain that far behind everyone else.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 6:44pm
Well, my OM only distinguished "LIFT" type or "Flat Beds" , you're splitting hairs now Mr MillerClapClap, and got called out IMO Embarrassed .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 8:13pm
Not really, YOU failed to be specific, a lot counts upon what is Asked and HOW Asked, you asked Poorly, as usual and got the usual type responses.  When you use Diction accordingly then answers will be more direct and as such more directed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 2:54am
had my dually towed ona flatbed wrecker one day, he didn't remove any rear wheel, just drove accordingly! the outer fenders on my dually is wider than the wheel set. our tow operators pull/haul oversized loads all the time! i used to be a tow driver...lots of people would cringe at what i towed!
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 8:02am
"Why it an "OUTER REAR" removal ?? Isn't the "inner" wheelbase the same as a NON DUALLY ???"
FYI.   Wheelbase is measured from center of front axle to center of the rear axle (lengthwise of the vehicle).  If you had a multiple rear axle arrangement (not commonly found on a factory built dually pickup, in case you wonder) you might say you have an "inner" wheelbase, if you measure to the forward rear axle.  The distance from one side to the other is called tread width.  It is measured from center to center of the tire treads, across the vehicle.  On a dually the rear axle tread width is measured to the center distance between the inner and outer duals.  Then there is inner track and outer track dimension measured between the inner and outer dual treads respectively.   On dual wheel vehicles the rear axle tread width (center between the duals), not the inner track width, may match the front tread width.
Edited by Jim.ME - 30 Mar 2022 at 8:03am
John m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 8:49am
Is it just my phone or does everyone have trouble seeing the blue writing? Noticed that on some other posts before.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 8:56am
Coming thru, a nice crisp blue color on my end, easy to read.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 9:22am
you can change the colour and sizes and BOLD, italics, even underlineSmile
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 10:58am
For sure some of the colors people post with are very hard to see on a phone, then on a computer no problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 11:15am
Sorry, I didn't intend for it to post blue, not sure what happened.
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 12:02pm
Hummm, wonder if they use that blue feature on Ford ovals
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 12:16pm
It looks pretty close!  Something fishy in here!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 12:27pm
Maybe auto-correct thought he might understand the difference in wheelbase and tread width better in blue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 5:47pm
THAT'S where it went!Wink
