D 14 oil line question |
Post Reply ![]() |
hendricsp@aol.com ![]() Bronze Level ![]() ![]() Joined: 27 Mar 2022 Location: Marquette Michi Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Mar 2022 at 12:03pm |
There are two oil lines in the governor one goes to the T on the block. Where does the other line go?
Also does the oil line on the side of the oil filter base for the oil pressure gauge? Thanks in advance |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88105 |
Peter, you put your question in the "FORUM TALK" section.. Not as many LOOKERS in this area.......... You will get a lot more attention if you repost in the "FARM EQUIPMENT" forum at the top of the FORUM LIST PAGE.
Edited by steve(ill) - 27 Mar 2022 at 12:34pm |
Thanks I see the line on the governor but I don’t see where it goes? Almost looks like it goes to the distributor from your picture. Thanks
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24724 |
jes follow the tubing... it goes vertically into a TEE, the top,right of the guv, there's a short piece of tubing from the T to the dist.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Moved from "Forum Talk" page.
Post Reply ![]() |
