HD5B Tracks Lubrication
AndyG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyG Quote  Post ReplyReply Direct Link To This Post Topic: HD5B Tracks Lubrication
    Posted: 25 Mar 2022 at 3:24pm
What weight oils do you use for the rollers, 80 or 100 weight or more? Would running through a plastic tube using gravity work, or what kind of pump to use?
Thanks. Andy G.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2022 at 5:16pm
Any suction type oil installer should work.  They look like a grease gun, but have a clear plastic hose, instead of a grease hose.  As for the fluid, I'd say as thick as you can get...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyG Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2022 at 9:05pm
Great, appreciate your help, thanks!
Lee Bradley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lee Bradley Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 3:55pm
You might try John Deere Special-Purpose Corn Head Gun Grease
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 5:42pm
Only real problem with this, AKA thixotropic grease, is getting it into a roller. I think its too thick to use in a suction transfer gun...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 10:40pm
You could use a pump type grease gun with a straight pipe (no end for zerk) and insert into roller  then pump 000 weight grease or heavy oil into space until it flows back out around tube . Remove unit and replace plug
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 8:40am
I've used these in the past on IH rollers. Thread one hole onto the grease gun tube, and seal against the port, fill the cavity till grease starts escaping the other hole:
You would need to select the size needed for your application.
PPGAndyG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PPGAndyG Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 12:48pm
Thanks everybody for the information...right now I'm still trying to get the track back on.   Since the ground is soft and it's on a hill, every time I jack the front up after getting the rear blocked, it slides forward and left down the hill.   If the track wasn't jammed towards the machine, I could raise it with the bucket and block the front better.   One step forward 2 step back right now...
