Need help identifying ring from HD4
Daelric View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daelric Quote  Post ReplyReply Direct Link To This Post Topic: Need help identifying ring from HD4
    Posted: 25 Mar 2022 at 10:30am
I was walking in an area of my property the other day where I last used my HD4 and found this on the ground. It's obviously from my machine, but not being a mechanic I have no idea where to even start to think it might be from, or how important it might be. I'm inclined to think pretty important though since it seems to be some kind of retaining ring /clip or something. Any help identifying it would be appreciated!
Edited by Daelric - 25 Mar 2022 at 10:31am
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2022 at 10:55am
retainer clip for lift cylinder pin?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2022 at 5:11pm
X2...Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 11:01pm
Check the back of machine on under side or rear housing where inner axle bearing cover is located .
Then as it looks like external snap ring could be from hyd cylinder pin retention
Edited by Coke-in-MN - 27 Mar 2022 at 11:03pm
