AC 175 Diesel question
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: AC 175 Diesel question
    Posted: 23 Mar 2022 at 6:26pm
So I used the tractor for the first time...first time I owned a diesel tractor.
Notice a lot of smoke? coming out the vent tube  off the head.  Is that normal?  Exhaust seems fine.
Also noticed the tractor seems to run a little hot.  Otherwise runs fine.
Friend said there may be a connection between the two. Said replace the thermostat.
Lastly is there a way to adjust the remote ram lift rate?  The valve seems very touchy..goes up in a hurry, too fast to my liking.
Thanks
tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2022 at 6:45pm
Do you mean out of the hose attached to the valve Cover? If its white like a fog its blow by. As a engine ages this is a normal occurrence. How many hours are on it? At what temperature is the gauge at when you say its hot? 170-180 degrees would be a normal range.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2022 at 6:55pm
Yes thats what I am talking about.  It is white.  Hours are under 2000's if to be believed.  Cant remember the temp exactly but I know it was right on the "red zone"...will have to make a note of it next time.
Thanks for the response.
Sorry I meant hours in the 2000's , not under.
Edited by TomYaz - 23 Mar 2022 at 6:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2022 at 7:13pm
Tom that’s very low hours if the tach works and its original. Simple things first. Have you checked the antifreeze level? Pull the oil dipstick, is it clean oil or is it white and foamy?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2022 at 7:21pm
Yep tach works.  Dont think it rolled over as the tractor is in decent shape.
Will check the dipstick
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2022 at 7:25pm
The gauge or electric sender (if it has one) may be off.
Verify actual coolant temperature with an infrared thermometer,
or cooking thermometer. Calibrate thermometer
with boiling water, that would be 212F.
Blow-by could be worn engine.
If it were a gas engine I would do a compression test first thing.
With a diesel, you have to pull the injectors. Need an adapter
to fit the situation. Then the fuel line will leak when you put it back together.
I don't know much about the 170/175 3pt lift. I think all the valves, linkages and
lift cylinders are external. It could be linkage that is rusted up or stuck with dirt.
Get an owners manual and read if there is a response control of some sort.
soggybottomboy View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2022 at 10:31pm
Make the easiest checks first. Engine oil and coolant level as mentioned. Then make sure the fanbelt is tight. If those are ok, put in a new thermostat as mentioned. If that doesn't change anything then take the radiator off and have it cleaned by a radiator shop if you can find one. If you should happen to need a new radiator, get one with an extra set of rows(thicker)and then put a larger driven pully on the fan to slow it down. That quiets the fan noise and makes that model more pleasant to drive.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 7:55am
Sounds to me like a bad head gasket, and the blowby is steam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 8:03am
Lots of suggestions/advice.  Thanks for the input.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 2:50pm
Ok a small update.
Oil looks fine, no water.  If I am to believe the temp gauge it was running at 220F wihle not really working...just spraying 100 gal at slow speed.
Next step is to drain the coolant and see if I was low.
Tom
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 4:04pm
I would also get the rad boiled out. 220 Doing light duty work is not right. How's the water pump?
I run a 180 degree thermostat and it never moves past the middle of the green zone, regardless of what I am doing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 5:04pm
Not sure...I guess no way if knowing unless you rip it out and examine.  Will be on the checklist if not resolved...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 6:25pm
The radiator must be FULL. By that I mean a couple inches from the very top. This means crawling up on the tire and checking it. With the engine off and stone COLD, turn on the key. The temp gauge should be clear DOWN in the cold range. Engine running wide open throttle for 20 minutes or more the temp gauge should barely be at the bottom of the green and no more. 220 degrees should technically be puking some out the overflow. I do not think it is that hot, bad gauge and sender but prove it instead of tearing things apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 6:35pm
Yep will do that, and get a temp gauge...bought one last year from harbor freight...where the heck did I put it???
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 6:52am
Folks,
Next step is to check the coolant level. Regardless if low or not going to replace the fluid as have no idea if when was ever done.
Question: where is the best place to drain coolant?  I am going to assume a valve on bottom of radiator, but is there another place as well?   Service manual is silent.
Thanks
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 9:27am
Originally posted by TomYaz TomYaz wrote:
Folks,
Thanks
Tom
Right side of the engine block under the primary fuel filter.  Also should be a drain at the bottom of the rad - on the engine side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 9:34am
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 5:22pm
Well, the coolant level was about 3" below the filler neck....no core showing...what I was able to collect  was about 10 pints; but some of it missed the bucket.  Manual says 13 pints.  So dont think I was too low?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 5:46pm
Be careful refilling with coolant !!  I think those Perkins will air lock if you don't do it right. If you drained 13 quarts it HOLDS 13 or more quarts to be full.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 8:03pm
Care to explain how to do it right?  All I know is to pour in radiator...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 8:39pm
My 175 owners manual says 15 quarts...2 inches down in the radiator, not 3,  If you get 13 or more quarts in it, you're probably good to go. Fill slowly. Maybe have the nose up in the air to help burp it. Owners manual says nothing but I know there is a possibility, but again if you pour in the proper amount that means it's full.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 8:43pm
I think you mean pints?  My service manual says 13 pints and I drained around  13 pints give or take.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 8:47pm
Dont have my service manual with me but wonder if the 13 pints is capacity of just the radiator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 5:44am
15 QUARTS for the entire system. Same for gas and deezel tractors.
BigGuy1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigGuy1000 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 7:56am
Yes 15 QUARTS not pints!
And drain is on right side under the bottom of the fuel filter!!!!
Drain also on bottom left inside corner of radiator!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 8:02am
Yep found the drains...
Did the block plug first...
Then radiator....but radiator was emptied by block plug as nothing came out. ..
John m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 8:40am
Hopefully the radiator drain is not plugged up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 8:42am
got a couple drips  and thats it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 8:43am
will test when I do the flush
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 9:04am
With the radiator cap OFF and drain cock OPEN use a rubber tip blow gun and gently give it some air.
This page was generated in 0.173 seconds.
