C With Stuck Engine From 2009
Dick L View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Topic: C With Stuck Engine From 2009
    Posted: 22 Mar 2022 at 9:38am
Here is the tractor I rebuilt using all used parts that I took pictures as I measured the parts making sure they were in spec. I had to repair the drive shaft in 2017. Other than that I have not had to anything except change oil and replace sediment bowl gaskets and switch gas tanks. I put a new radiator on it that I had in my parts for 10 or more years. When I repaired the drive shaft I did changed the clutch and pressure plate. Both good used from my used saved parts. It is my lawn and manure mulching tractor mower. Last year I rigged it to chop hay for the horses. Starts easy every time and does not smoke.  Pictures to show it has not been low use tractor.
Forgot the link!
Edited by Dick L - 22 Mar 2022 at 10:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2022 at 12:25pm
That just goes to show you what can be done if you take the time to inspect everything.  I have done a few "economy" rebuilds.. I normally use new gaskets and piston rings... But used pistons, liners, valves, cam, even crank bearings can be reused or replaced with those from a spare engine ..... EVERYTHING does not have to be EXACTLY to factory spec to be "good"............. Looks like you have proven than over time, Dick !!
