D19 3rd gear
Model 70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Topic: D19 3rd gear
    Posted: 18 Mar 2022 at 5:43pm
Working on replacing worn gear but can only seem to find one with 27/8 teeth. I’m assuming mine is original being it has I believe 30/8 or31/8 teeth. Rough count. Do I need to replace a gear on counter shaft if I replace gear with the 27/8 gear. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2022 at 5:50pm
If the actual diameter of the gear is the same, but tooth count is different, you must change the gear it mates with so they are the same tooth pitch. Compare it to trying to use #60 chain on #50 sprockets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2022 at 6:30pm
What is the best way to remove the counter shaft and reverse idler shaft ,book says to screw in slide hammer threaded fitting into front of shaft but I sure don’t see any threads in the shaft ? Changing bearings on shaft. Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2022 at 6:35pm
Reverse idler shaft doesn't need to be removed. Remove front or rear snap ring on the countershaft cup and with a punch or round shaft drive the other end until everything falls down inside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2022 at 6:41pm
Thank you for all the advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2022 at 7:23pm
While I’m asking questions I may as well ask about the 2 special dowel bolts for the shift cover, what do they actually do? Neither of my D19’s have them anymore. Can a guy make a them ? Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2022 at 7:43pm
Left front corner and right rear corner. They square up the cover to the transmission shafts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2022 at 7:48pm
I see exactly what your saying. Appreciate it Dr Allis.
