Foot Throttle On A D/100 Series ?? |
Page 12> |
| Author | ||
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Topic: Foot Throttle On A D/100 Series ??Posted: 15 Mar 2022 at 6:43pm |
Was it ever an option on these gals? If not, did any of you "farmerize" one ??
| Sponsored Links | ||
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 15 Mar 2022 at 7:41pm |
I have a D-10 that I like to take on caravans that I've thought about making a foot throttle for. Not sure how nice it would be to use.
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Posted: 15 Mar 2022 at 8:53pm |
Worked for a neighbor years ago that had foot throttle on JI Case 1175, 1030, 970, and a 770. He also had an 830, but the previous owner removed it. At times they are useful, but growing up on tractors that didn’t have them, never got into the habit of using them much.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Optional on D21. |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5474 |
Posted: 15 Mar 2022 at 9:06pm |
Charlie made one for his 190XT, works really good.
FREEDGUY
Funny that you mention JI CASE, I was a hired hand on 2 dairy farms that ran all Case tractors from a RC to a 1070, the 530,630,730 had the foot throttle. I don't recall it on the 830/930 though . There was none on the 870 or the 1070 that I ran for them. Man, that was a LOOOONG time ago Lars yet seems like yesterday now that I think about it ![]() !!Those '30 series Case machines were almost bullet-proof in that era, the '70 series P/S; not so much
DaveKamp
Posted: 15 Mar 2022 at 10:24pm |
A Decellerator pedal would probably be more useful in most circumstances... An accellerator would have to take the engine from low idle, up to some governed speed. A Decellerator pedal drops it from whatever governed speed, down to idle...
Wayne180d
Joined: 08 Dec 2015 Location: Gilman, Il Points: 5946 |
Posted: 15 Mar 2022 at 11:44pm |
I have a 1946 WC turned around with a forklift on it. No throttle only the foot throttle. Works good.
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Posted: 16 Mar 2022 at 5:35am |
The industrial models had a foot throttle.
My I600 has. |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 16 Mar 2022 at 8:48am |
I did farmerize one. Here is the video |
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
Dave (NE)
Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2164 |
Posted: 16 Mar 2022 at 8:56am |
my one-sixty has one on it and I'm surprised how quick I got used to it and use it
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12421 |
Posted: 16 Mar 2022 at 10:42am |
You mean like, .....taking your foot off the pedal?
Or, putting the throttle lever in the low position? Been driving tractor for close to 50 years......never wished I could do that with a pedal, but I've used a foot throttle most days for the last 20+ years. |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90834 |
Posted: 16 Mar 2022 at 12:45pm |
Hand preset throttle means just ONE LESS thing your feet have to do, or you have to think about... Normally set at a constant speed and GO... If your using it as a loader, or application where you need to change throttle position constantly,... maybe.
Charlie175
Posted: 16 Mar 2022 at 1:06pm |
Hater... ![]() ![]() |
Charlie
Tbone95
Posted: 16 Mar 2022 at 2:40pm |
? Not sure the angle you're coming from.....? I've ran, oh.....5 or 6 different tractors with a foot throttle, and they all have had both a hand and foot throttle, not a foot throttle instead. AND, they all have had the hand throttle act in a steady fixed position, but the foot throttle is spring returned like a car. Would never use foot throttle doing field work, between the bumps and your reaction, things get pretty unstable! But, for handling round bales, going across the yard, backing up to something sort of far away and covering the first part of the distance a little quicker.....there's lots of little things the foot throttle is handy for.
steve(ill)
Posted: 16 Mar 2022 at 3:58pm |
Would never use foot throttle doing field work, between the bumps and your reaction, things get pretty unstable! (Hand preset throttle means just ONE LESS thing your feet have to do, or you have to think about... Normally set at a constant speed and GO)... But, for handling round bales, going across the yard, backing up to something sort of far away and covering the first part of the distance a little quicker.....there's lots of little things the foot throttle is handy for. (If your using it as a loader, or application where you need to change throttle position constantly,)..
Well............ thats what i was trying to say...
Edited by steve(ill) - 16 Mar 2022 at 4:04pm |
Tbone95
Posted: 16 Mar 2022 at 4:52pm |
Yeah, I mean, I knew partly what you meant about the loader, but part of it sounded like you were like against it or something ( one less thing for your foot to do) and part of it sounded like you didn’t know they were temporary position type.
It’s all good, just being clear. |
steve(ill)
Posted: 16 Mar 2022 at 5:52pm |
Normally my feet are too busy planted on the floor board trying to stableize my bodyto worry about running a foot feed !!........... Our CASE 530 backhoe has a foot pedal.. Never have figured out when to use it !
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3671 |
Posted: 16 Mar 2022 at 6:33pm |
Charlie175, that’s a sweet XT with your new fabbed foot speed. Love those great 301 sounds! Thanks for sharing. Edited by AC7060IL - 16 Mar 2022 at 6:37pm |
FREEDGUY
Posted: 16 Mar 2022 at 6:43pm |
Sorry Dave, NOT talking about the CAT bulldozer set-up
. Strictly a foot pedal that over-rides the hand throttle ![]() .Edited by FREEDGUY - 16 Mar 2022 at 6:43pm |
FREEDGUY
Posted: 16 Mar 2022 at 6:49pm |
LMAO STEVIE !!!! You're the guy that can't chew bubble gum and spit at the same time
![]() ![]() !!! I'll bet you can't operate a "BOBCAT" brand skid steer with foot pedal boom/bucket controls either ![]() !!!! |
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3200 |
Posted: 16 Mar 2022 at 6:58pm |
5040 and 5050 had foot throttle as did all Fiat built tractors,especially handy doing loader work,just set the hand throttle at idle and use the foot throttle.My cars and trucks all have foot throttles did have a Model A Ford with a hand throttle one time.
steve(ill)
Posted: 16 Mar 2022 at 7:01pm |
sorry 4700 poster, but YOU and your WINKERS would be WRONG again !!
FREEDGUY
Posted: 16 Mar 2022 at 7:11pm |
LMAO !!!! You said yourself you couldn't figure out the backhoe pedal !!!! And, you left out 1/2 of my reply for some reason
![]() ![]() Edited by FREEDGUY - 16 Mar 2022 at 7:12pm |
FREEDGUY
Posted: 16 Mar 2022 at 7:44pm |
The CASE foot throttle was AWSESOME for dairy farm feedlot use
!! It was pretty useful for "tucking-away" machinery in the machine shed also
DonBC
Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 947 |
Posted: 16 Mar 2022 at 7:49pm |
I made one up for a D grader. Helped with double clutching when shifting on the run. It also had too many things that needed operating with your hands.
FREEDGUY
Posted: 16 Mar 2022 at 7:57pm |
Thanks Charlie for your input
steve(ill)
Posted: 16 Mar 2022 at 8:00pm |
POOR IGNORANT 4700 poster.... I said their is NO REASON for the foot pedal on a backhoe .
bigal121892
Posted: 16 Mar 2022 at 8:01pm |
Steiger tractors had a decelerate pedal, I though it was pretty handy.
FREEDGUY
Posted: 16 Mar 2022 at 8:38pm |
And for some reason you omitted half of my statement
Page 12> |
