7060 Clutch Return Spring
tractorman21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman21 Quote  Post ReplyReply Direct Link To This Post Topic: 7060 Clutch Return Spring
    Posted: 14 Mar 2022 at 9:17pm
    Hello,
          The clutch pedal return spring broke in my 7060 while sitting over the winter. I ordered a new spring and for some reason I am not seeing where it hooks on the bottom of the floor/cab. Is there a piece that fell somewhere when the bottom part of the spring broke? I have tried looking for a diagram of how everything should work, but I am clearly overlooking something.
Any thoughts or suggestions are greatly appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2022 at 8:07am
It hooks straight forward from peddle. Remove left hood and lower side panel. There is a key that the spring hooks to through fire wall.                     MACK
Mattman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2024 at 6:09pm
Would you happen to have part number for spring?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2024 at 9:39pm
#70272167 spring. You may need the link,#70272168,depending on the serial number. This is for a power shift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2024 at 3:21pm
Lynn, your response with part numbers is greatly appreciated!
