Foamy Radiator
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Topic: Foamy Radiator
    Posted: 25 Sep 2010 at 1:10pm
I know that usually when you have bubbles in your radiator  coolant that means a blown head gasket. But I have changed the head gasket twice (first time had it on wrong) and even had the heads took down to a machine shop to be tested for cracks. Neither the head on the 41 or the 37 was cracked. I don't know if water pumps could cause this because mine, where it connects to the radiator hose, leaks. Could this be sucking air in and doing that?
I don't really know what I'm talking about so some of this may sound weird. Do any of you guys have any idea on what could be causing this?
Thanks,
Jeremy
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 5:19pm
What does the foam look like? It usually takes some type of added chemical to foam. To just make bubbles it could be the water pump. A cracked sleeve could also blow bubbles like a blown gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 6:00pm
It looks like someone dropped Alka Seltzer in the radiator.
