What Engine ??
 Rating: Topic Rating: 1 Votes, Average 1.00  Topic Search Topic Search  Topic Options Topic Options
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: What Engine ??
    Posted: 12 Mar 2022 at 6:48pm
Borrowing my dads '11 FORD F250 cab & a 1/2 AND a true 8' bed SmileSmile !! My question is, WHAT gas engine is in this pig that gets WORSE MPG than my 5.4 with a 9' service body  EmbarrassedConfused ?? I can give a VIN # if needed Embarrassed
John m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 6:52pm
Geez if he wants you to borrow his truck anymore tell him he's gonna have to chip in on the fuel. How dare him. Lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 7:00pm
Raise the hood and take a look see Wacko Or if that's too difficult, maybe you could google it Lamp
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 7:02pm
Answer the ?? Dipstick ClapClap !! let me guess , you pedal a GM Product ClapBig smileWink !!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 7:06pm
I think it runs on batteries.... Check the solar panel plug in..
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 7:06pm
[QUOTE=PaulB]Raise the hood and take a look see Wacko Or if that's too difficult, maybe you could google it Lamp[/QUOTE
Can YOU determine the engine by "raising the hood" ????? It's NOT like it's imprinted on the air filter cover like on the engines of the era where you were conceived of in a back seat Big smileWinkClap !!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 7:11pm
Thumbs Up   Thumbs Up   Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 7:31pm
You are WRONG STEVIE !!!! I went out and popped the hood and NO engine designation on the "intake" cowling  Clap!!!
bemer848 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bemer848 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 7:33pm
Freegas does not know how to open the hood and look at the label.Yin YangGeekClown To many beers already.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 7:35pm
If it has the 6.2ltr V8 gasoline engine, they were hard on fuel but had good power.
Not really something to get groceries with.
The engine will be identified on the emissions sticker on either the radiator support, or air inlet piping.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 7:39pm
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bemer848 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 7:40pm
Freegas if you go green you would not have to worry about the price of fuel.QuestionWacko
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 7:44pm
Thanks Codger, is the engine inf in that location for "most'" Ford trucks of any year ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 7:49pm
Sadly Stevie, I don't know what's worse, your photoshopping or your YT "facts" to get a rise out of the newcomers Confused ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 7:55pm
Poor gassy...  Daddys truck uses too much gas!Wink
I'm hoarding gas...
Pull my finger!LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 8:00pm
Not really. The underside of the hood panel, atop the air filter element, as mentioned radiator support, and at times the actual engine cover. It can also be identified on the driver's door jamb decal but will take a decoder to decipher.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 8:00pm
When the new school year starts next fall, will you be moving into the kindergarten class or 1'st grade SmileLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 8:02pm
I'm hoarding gas...
Pull my finger!LOL
Keep on tugging Davy ClapClap
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bemer848 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 8:09pm
Put your free meth pipe down.Ouch Is staying in the basement getting to you?ClownYin Yang
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 8:18pm
its got that FULL SIZE 8 FT BED to hold all them BATTERIES... solar panels on the 1-1/2 cab roof !  Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 8:46pm
usually there's a sticker on the rad support that has belt routing/EPA krap , will have engine info.....
VIN for sure WILL have engine info, diff gears,tranny stuff....
Fun fact... if the driver's doors been replaced be SURE the clowns do NOT scan it for ID info !!!!
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 8:50pm
DIY Dave is there a pun in here somewhere?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 9:00pm
  1. Ah, but a good pun is its own reword.Wink
Edited by DiyDave - 12 Mar 2022 at 9:01pm
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 9:26pm
I guess I find this question a bit strange.  I always knew what engines my parents' vehicles had, at least from the point I could drive.  Then after we were married, I knew my wife's folks' vehicles as well.  I guess that was because I helped take care of them.  Each to their own.
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 9:27pm
Guys I'm with Freed on this one.  I don't know about a Ford but when I looked under my hood on my Chevy  (regular cab 8 ft box replaced by bale bed)Wink and looked at that little label with all the info right beside motor it just said BROKE.  I think it must mean if it won't start it's broke and if it starts you'll go broke buying gas.  Apparently Chevy doesn't need to designate motor size. Unhappy
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 9:48pm
Motor designations fall in the same catagory as blue ovals, rail road crossings, fish sandwich, chicken meals, gas prices, motorcycles, 8 ft truck beds....
what kind of idiot can not open the hood and READ what motor is installed ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 10:05pm
Well maybe this explains it.LOL
https://pics.me.me/drunk-mechanic-what-could-possibly-go-wrong-posted-by-bridget-16274706.png
soggybottomboy View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 10:13pm
In the 2011 model F 250 the standard gasoline engine was the 6.2 liter. Thats what I have in my truck. I have always been a chevy man, but at that time I didn't think I wanted to reward the union for taking over GM so I bought a Ford. That engine is kind of frustrating to me, because it is an absolute dead dog until you hit the power band which starts at 3500 rpm. Hauling a load of 11 big round bales that engine is screaming most of the time. It has good power up there though, and it doesn't do to bad on gas when I'm just going to town. I wish the companies that make pickups would build a gasoline engine that would pull at 2500 rpm. They could too, but it's all about horsepower these days, and the figures have to look good on paper. You can't make impressive horsepower figures when the torque band is lower. But I'm thinking these trucks would get better mileage if the torque band was lower, because in normal highway driving the engine rpm would be closer to the sweet spot. Why don't one of you guys start making them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2022 at 5:19am
2. Poor gassy, he can't VIN, for losing!Wink
3. C'mon guys, the mo tor merrier...LOL
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2022 at 5:58am
If it's not a diesel it's a 6.2. May have 16 spark plugs.
8 on top under the coils and 8 down by the exhaust manifold.
