D17 oil pan removal?
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Topic: D17 oil pan removal?
    Posted: 24 Sep 2010 at 11:39pm
I finally got around to checking out the D17 I bought last spring.  It had about 2 gallons of water in it along with the oil when I drained it.  Removed the pan bolts but can't get it off because the PS cylinder is on one side and the steering shaft on the other.  Can I get the pan off just by removing the steering shaft?  Is there a bolt a bolt above the PS cylinder?  All advice is always enjoyed.
Allis Express participant
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 12:59am
John, there is one bolt by the steering cylinder near the front of the engine.  It is an allen type head that is removed from the top (not like the others from the bottom).
The pan is best removed by moving out the front axle first.  It is pretty quick and easy, and gives you total access to the pan from any angle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 1:46am
It's a tricycle front.  Thanks for the advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 12:45pm
Ditto on pulling the front steering housing off. LOTS easier to get at it with nothing in your way. I cribbed up my D17 under the clutch housing and pulled the housing off with a cherry picker. Mine's a NF too.
