Cracked brake housing |
John m
Joined: 11 Apr 2020 Location: Wetmore, Mi Points: 278 |
Topic: Cracked brake housingPosted: 06 Mar 2022 at 4:51pm |
In the process of replacing the brakes on my 190xt. While cleaning the brake facing in the brake housing I see there is a small crack. It's about 3/4 inch long going from the center towards outside of housing. Should I look for a replacement housing? Opinions? Thanks John
DrAllis
Posted: 06 Mar 2022 at 6:33pm |
There are thousands of them running with more cracks than that.
John m
Posted: 06 Mar 2022 at 6:52pm |
Thanks Doc. Parts should be here Tuesday, I'll start putting her back together. John
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25275 |
Posted: 06 Mar 2022 at 7:28pm |
If you drill a small hole at the end of the crack, it won't get any worse...
John m
Posted: 06 Mar 2022 at 7:59pm |
Sounds good, thanks
