HELP Identifying AC Forklift
rdoran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rdoran Quote  Post ReplyReply Direct Link To This Post Topic: HELP Identifying AC Forklift
    Posted: 06 Mar 2022 at 2:34pm
Hello,
I am looking for assistance identifying this AC forklift. No tags or serial numbers have been found on it.  About the only the thing marked on it is the engine tag for a Econmobile straight 6.  Thanks for your help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rdoran Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2022 at 2:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2022 at 5:02pm
I think it is BIGGER than ACC60...... but same design...
Edited by steve(ill) - 06 Mar 2022 at 5:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2022 at 5:12pm
If you look at the strap welded to the fender above the front tire, it "may" be an ACC80.
some "SPECS"... discussion here
https://www.allischalmers.com/forum/acp80-forklift_topic184767.html
Edited by steve(ill) - 06 Mar 2022 at 5:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote rdoran Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2022 at 5:48pm
Thank you, I'll look for that strap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2022 at 8:48pm
I mean i see the strap in the photo... on the side of the machine, around the front tire... the "Z" shaped strap.... Not on the 40 or 60 size tractors...
I dont know what an Econmobile is..... I thought the forktruck would have a 6 cylinder ALLIS (BUDA) motor.
I believe the DATA tag was pop rivet to the dash board on the right side.. normally aluminum and about 4 x 4 inches.
