605B AIR COMPRESSOR
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: 605B AIR COMPRESSOR
    Posted: 06 Mar 2022 at 7:44am
HELLO
I'M LOOKING FOR A COMPRESSOR W/PULLEY AND MOUNTING BRACKET FOR A 605B EVEN A CONTACT FOR SALVAGE YARD THAT WOULD HAVE A 605B FOR SALVAGE
   THANKS
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2022 at 8:47am
look at the compressor and see if there is a name like BENDIX on it.. Then GOOGLE that name and part number if listed.... (assuming you have the compressor)....Not too many "original" compressors around today... You might stop by a TRUCK REPAIR SHOP and works on big diesel / semi... and look at their compressors and mounts and ask about a unit. ........... assuming you get no other takers for an Original.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2022 at 8:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2022 at 9:00am
THAT'S MY PROBLEM I HAVE NOTHING, STARTING FROM SCRATCH, AND FROM WHAT I UNDERSTAND THE PULLEY ON THE COMPRESSOR IS A SPECIAL PULLEY ,THAT'S HOW YOU TIGHTEN THE BELT ,THE COMPRESSOR IS STATIONARY IT DOESN'T MOVE
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2022 at 9:05am
I dont remember that.. Have not seen one for years, but i thought it was just a standard pulley.... I think i would look at parts book for drawings... and stop by BIG TRUCK shop for comparison on how they do it........ Good luck with finding "original" ... dont see too may links to that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2022 at 9:18am
THANKS FOR HELP AND INFOHandshake
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2022 at 11:53am
The pulley it seems is the type used on my old White truck , the hub is threaded and outer side of pulley moves in and out on those threads to tension belt .
This page was generated in 0.146 seconds.
