6080 fuel injector "seeping" leak
ssefick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Topic: 6080 fuel injector "seeping" leak
    Posted: 05 Mar 2022 at 5:07pm
Hi everyone:
On this forum I found that a seeping fuel leak at the injectors is likely either the head gasket or the return lines. It is NOT an actual injector leak.
Is this what everyone thinks? Looks like fuel is seeping frome the bottom of the injectors when the engine is warmed up. Does not seem when not warm.
I will check the banjo bolts tomorrow after studying the manual tonight
Thanks to everyone, and please let me know if I can help by taking pictures etc.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2022 at 5:13pm
Also check valve cover gasket it runs into the injector runs out when it gets hot
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2022 at 5:50pm
    Do what Alvin says. Check gasket.
   J Carlson
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2022 at 6:02pm
poor quality rebuilt injectors can leak at the mated surfaces inside, and therefor cause it to leak externally.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2022 at 8:58pm
Definitely not head gasket, but valve cover is quite likely
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2022 at 9:20pm
I agree on the valve cover gasket. I went thru this same thing and this forum educated me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2022 at 9:02pm
Thanks everyone. I am learning as I go. I got confused about the valve cover and the head gasket.
I snugged up the drip line bolts and valve cover. Drove the tractor around the field. Everything looked fine, parked, throttled down, and hopped on off to find leaking occuring.
I'll call the parts man tomorrow morning to get a gasket.
I need to glue this gasket with some sort of gasket glue, correct? I'll ask the parts man, but do y'all have any suggestions?
I would like to replace the Phillips head screws with hex head bolts. Is this possible? Any suggestions.
All of you are very helpful. I really appreciate it!
160 allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 160 allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2022 at 5:29pm
I don't use any glue or sealant on my valve cover gaskets. I've done 4 185 tractors in the last few months and no leaks yet. I hate when I see them with gobs of silicone pushing out everywhere. Others may do it differently but that's just the way i do mine. Also, get a agco gasket if possible, i got one from djs and had to trim the edges where the bolts go through in order for it to fit inside the valve cover. Never had to with the agco and they are cheap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2022 at 5:49pm
If you don't clean the valve cover gasket surface well, and glue the gasket to it (3M yellow 8001 weather strip glue) you will get to do it again. Once the gasket glue has set up and dry, rub a thin coating of oil resist RTV on the gasket where it will contact the head. Clean the head with brake kleen before assembly. I've been doing it this way for 45 years and maybe after 10 years of use they start to seep and it's time to run the valves anyway.
Edited by DrAllis - 07 Mar 2022 at 5:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2022 at 8:26pm
Thanks guys. I will not use rtv. I'll clean well. I would like to replace Phillips head with hex bolts.
Like I said, I am learning as I go. Anything special I should look for, or should I just go to the hardware store and get a hardened steel bolt that fits?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2022 at 7:09am
If you replace the screws, go to allen bolts, hex bolts don't fit well which is why they use phillips head screws, or later AC used small head hex bolts with the spring packs to maintain tension.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2022 at 1:24pm
All the spring pack kits ive had used shoulder bolts so you could only put so much tension on the belvile springs
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2022 at 9:23pm
While I have the valve cover off I should probably adjust the valves, correct?
If yes, I have a couple of questions.
1. How do you know it is time to adjust the valves?
2. How do you turn the crank shaft? The starter? The fan? A breaker bar on the fly wheel nut?
3. While I have it open should I be looking for anything else?
Thanks everyone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 160 allis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2022 at 9:31pm
Any time the valve cover is off a tractor you don't know the history on is a good time to run the valves. Valve adjustments are often overlooked on a lot of tractors since it's a pain to get to the valve cover. I always use a socket or wrench on the crank pulley to turn the engine over until I reach tdc. On 185 tractors you gotta take the 2 bolts off the plate that goes across the bottom below the crank gear before you can access it. Not sure if the 6080 has the plate as i haven't worked on one. Look at the rocker arms and everything while you're in there. Hope this helps.
Edited by 160 allis - 16 Mar 2022 at 9:34pm
