180/d17
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Topic: 180/d17
    Posted: 24 Sep 2010 at 9:27pm
I am looking at a 180 and a d17 series 3   Both in excellent condition and always sheded wonder what they are worth  180 is the last year they were made with 2 speed pto diesel 4xxx hrs w/ cab in good shape  D17 about the same maybe rear axle trouble interetested in Values if anybody has an opinion   Thank You  Gary Roidt
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 7:55am
Just my opinion -- you don't say if the D17 is diesel , but assuming it is.  Always tough to guess without a lot more info -- but, I'd say around $3000 for the D17 and  maybe up to $4000 for the 180. Could be a little more if they are really excellent - and close to you. I'm willing to pay a little more for something I don't have to travel far to get. If the D17 really has rear axle trouble, the price would drop significantly.
LannyMTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LannyMTN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 8:19am
180. Great tractor for chores or field work . It is worth about twice as much as the D-17 you mentioned. Series IV, D-17 would be a different story.
Edited by LannyMTN - 25 Sep 2010 at 8:28am
MBolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBolton Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 8:22am
The 180 would be choice!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 12:38pm
It depends on what shape they are in mechanically. I gave $2500 for a series 1 D17 diesel that ran good, has good tin, and needed 4 tires. If it has rear end troubles, there's no way I'd give $3K for it. I'm thinking more on the line of $1000 if the tires are good and the engine is ok for a gas. Maybe $1500 if it was a good running diesel.
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 7:53am
One-Eighty is better choice, I think?  It will have updated hydraulics that you can use on most any later hydraulic setup, heavier 3pt, & 301 diesel for around $5000.  Cab is a bonus for cold weather.  The D17 series 3 if powered by the gas 226 is tough to beat for cold weather starting as a chore tractor.  Those will fire off even below zero.   Probably around $2500 for it.
