H3 weight?
chevytaHOE5674 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chevytaHOE5674 Quote  Post ReplyReply Direct Link To This Post Topic: H3 weight?
    Posted: 24 Sep 2010 at 9:26pm
I am looking at maybe buying an H3 gas dozer. Wondering if somebody could tell me the weight of a gasser with a 6 way power blade? Wondering if I can pull it behind a 3/4 ton truck with a bumper pull trailer....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2010 at 10:48pm
Weighs approx. 7400 lbs. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote chevytaHOE5674 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 7:07am
Thanks, is the the weight with the blade? I've heard some people say they weight upwards of 10,000 and thought that was a little heavy.
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 9:35am
The spec sheet that I have say the base unit is 7100lbs operating weight. On mine with the loader bucket it was 9800lbs. A blade should be slightly less.
1961 H3
Post Options Post Options   Thanks (0) Thanks(0)   Quote chevytaHOE5674 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 9:38am
Hmm I'm thinking its a little to heavy to haul with the trailer I have at hand especially since it would be quite a distance and across state lines...
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 12:37pm
I  brought home a HD3 crawler with my 12000 GVW trailer and my father in law's 1 ton Ford Diesel.  Truck handled it no problem, trailer showed the wear though.  I don't think I would take it a long distance unless I had a heavier duty trailer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chevytaHOE5674 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 1:58pm
Hmm the seller was saying he hauls it routinely on a normal car hauler trailer without any issues. Have to investigate further.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 7:57pm
My old 180 with a loader, and the 8 foot bush hog runs out close to 9000#, I haul it on my Super Duty and a 14000# rated goose, no issues.
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 12:16pm
Gooseneck being the difference. Pulled my H3 with a 18k trailer and a C30 dump.
1961 H3
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 4:05pm
I have an HD-3 with a 6 way blade. We have moved it for at least 5 years on a 12,000 Felling trailer with torsional axles, and pulled it with a 2001 Super Duty with a 7.3 diesel. Weight of the HD3 is published by AC @ 6300 pounds with a 5 roller track frame and 10" shoes.  The 1080 six way blade is an additional 1563 pounds. I would guess our tractor to be about 8000# as it has PTO and 14" shoes.
Ricky D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ricky D Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 2:23pm
I think Cat is pretty close to dead on the weight  Ricki D
This page was generated in 0.359 seconds.
