Stainless steel angle iron |
200Tom1
Topic: Stainless steel angle ironPosted: 01 Mar 2022 at 7:05pm |
Anybody have any idea where a guy could get about 12'. Must be 2"X 3" 3/16 thick. I have seen some sites with unpolished stainless at $800.00 for each piece. I thought that was quite high.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90892 |
Posted: 01 Mar 2022 at 7:15pm |
you might call these guys... "MOST" angle iron sold has equal legs...
steve(ill)
Posted: 01 Mar 2022 at 7:26pm |
Ryerson can get 2 x 3........ call for price
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8662 |
Posted: 02 Mar 2022 at 5:04am |
McMaster Carr may have some, but 12 feet maybe not??
Codger
Posted: 02 Mar 2022 at 5:33am |
Try Shapiro Supply in St. Louis. They will ship small quantities and are priced pretty fairly.
Edited by Codger - 02 Mar 2022 at 5:34am |
thendrix
Joined: 04 Feb 2013 Location: Fairmount GA Points: 5183 |
Posted: 02 Mar 2022 at 5:42am |
I don't know if they've changed but, if I remember correctly, 6 ft used to be their limit |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25274 |
Posted: 02 Mar 2022 at 5:53am |
do you actually NEED SS ,those dimensions and a 12' single piece ? If so..the you'll have to pay. Any chance you can use an alternative ?
steve(ill)
Posted: 02 Mar 2022 at 9:00am |
Most places will have 20 ft lengths or so... You could buy 12 ft, but they normally sell 5-6 ft as it is easier to SHIP.... If you want 12 ft ONE PIECE, look local, or it will be shipped on a Big truck.
200Tom1
Posted: 02 Mar 2022 at 8:09pm |
Guys it has to be cut into 2" lengths with 2 holes drilled in them. Sorry I didn't make that clear.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42274 |
Posted: 05 Mar 2022 at 11:19am |
Hmm - drops are sometimes cheaper - but 12' of drops of 2" each if they cut is going to be expensive .
Son just got steel on Thursday - what he ordered last year of same weight and size is now 3 times the price . , most was 2" x 2" x 20ft box tube .Then they charge a delivery fee if order is not over $800 - that was no problem as the bundle I unloaded was $2,500 |
jaybmiller
Posted: 05 Mar 2022 at 11:26am |
re: 2" lengths with 2 holes drilled in them. well that is a different kettle of fish !!! find a local fab shop, dumpster dive(with permission) if not, find online in small sections, then have a shop punch holes and cut to 2" 'HAS' to be stainless ? if so, what grade(that'd be a spec to....)
Trawler II
Joined: 04 Jul 2017 Location: Missouri Points: 3642 |
Posted: 05 Mar 2022 at 2:40pm |
Not sure if you have any wiggle room on your dimensions. If you do you might look at a product called Unistrut. They make SS angle clips with punched holes. Type 304L stainless. You may be able to modify or adapt to suit your requirements.
If not a metal fabricator should be able to cut and punch the angle to your specs. 800-586-4787 Try this number, distributor in Ohio. With your quantity they should be able to ship UPS small package. Edited by Trawler II - 05 Mar 2022 at 3:15pm |
"Most people find it easier to believe a simple lie, than the complex truth"
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 727 |
Posted: 05 Mar 2022 at 4:40pm |
Try speedy metals online. Best i can tell 6 2 ft pieces is 300.00.plus shipping
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
