Late 190XT series 3 serial numbers
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Topic: Late 190XT series 3 serial numbers
    Posted: 28 Feb 2022 at 2:24pm
Does anyone know what the last series 3 serial number? I have number 30507 anyone else have a high serial number tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 2:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 4:35pm
the bible says 1973 sr#31118–31140
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 4:37pm
1971 sr#29136–31056 is yours
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 6:09am
I used to own #30991
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 8:14pm
I thought the 190XT was replaced by the 200 in 1972........ unless the straight 190 continued for a while longer and is in sequence with the XT models.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 8:32pm
It did. They had a few One-Ninety parts to use up, and it always was slightly larger than the new 185 tractor.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 9:00pm
Then I would love to find a 1973 model. Were they decaled "Landhandler"?
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2022 at 8:08am
Yup lonn I’d like to have a 73 to
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2022 at 7:00pm
We own 30430
Amateur Rancher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amateur Rancher Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2023 at 5:01pm
I have my grandpa’s he bought new, sitting in the barn. Comes out for about a week a year to mow pastures. #30999
6080fwa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 6080fwa Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2023 at 12:39am
Have a 190 not an xt serial number 190 31125! could it be the last 190 to roll off the assembly line?  anyone ever heard of one newer?
d19d d19lp 175d 190d 190gxt 190dxt 200 6080 7000 8010 9150 9190
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2023 at 6:02am
Could be. Unless there is a 31126.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2023 at 7:01am
Amateur rancher welcome to the forum.
6080fwa do you have pictures
Post Options Post Options   Thanks (0) Thanks(0)   Quote 6080fwa Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2023 at 11:10pm
having trouble posting pics on the forum....any ideas where to find out how to?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2023 at 4:41am
The highest Serial on the Forum Registry back in 2019 was 30935XTD
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2023 at 7:48am
Wonder if the registry will ever come back
lukeWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lukeWI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2023 at 3:29pm
uploads/806/190.jpg
photo for 6080fwa
www.olsontractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2023 at 5:35pm
Interesting. Stamped on the right side and a straight One-Ninety, not an XT.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2023 at 6:05pm
Stamped on right like a 200. Any 190 within the serial number range mentioned above, 31118-31140 would only be a straight 190 Diesel. XT production ended before that. They really should have given them their own model and serial numbers, so many people get confused. Did some end up being built as Hi-Crops? Interesting thread, the first tractor I drove at 7 years of age was a 190D, that was a 69 or 70. I still have the hand written receipt dated 1970 when dad bought it new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2023 at 7:58pm
Ok so if they aren’t labeled it. Is there any difference. I mean we always get a 190xt series III. But are these last ones have all the things in the xt series III
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2023 at 9:17pm
I can think of two things that would be different between the late One-Ninety and One-Ninety XT series III after s/n 23001 and newer as far as the driveline goes. The XT would have had a hydraulic oil cooler ahead of the radiator, where the One-Ninety did not and the Power Director and PTO clutches disc/plate count total could have been different between 77 HP and 94 HP. But that should be it. There is no logical reason why the differential wouldn't have been 4-pinion style in BOTH tractors, to keep the parts differences between models the same. The only way any of us will ever know for 10000% sure is for someone to pull the PTO shaft on one of these 1973 models and look up inside with a flashlite, assuming the tractor is still original.
Edited by DrAllis - 08 Jun 2023 at 9:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2023 at 9:59pm
Thanks dr.
6080 have any pictures of whole tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2023 at 7:11am
That is the beauty of a 190D, you'll probably never see the differential lol! I know ours just ran and ran. We bought a used XT and had lots of problems with it, then it later got traded for a new 7000 with cab and AC, and we were really up town then lmao! The hired help could ruin an anvil though.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2023 at 6:52pm
ILGLEANER has a real late one. Its got some odd things about it.
