WTB D15 distributer |
JohnColo
Joined: 03 Apr 2020 Location: Niwot, CO Points: 1263 |
Topic: WTB D15 distributerPosted: 26 Feb 2022 at 10:14pm |
I assume they are the same on all the gas D Series, mine is so rusted it probably is more work to fix then a good one is to buy.
Matt (Jordan,MN)
Joined: 12 Sep 2009 Location: Jordan, MN Points: 3814 |
Posted: 27 Feb 2022 at 12:09am |
I believe there all the same. I have one off a D17 that i will sell. Send me a PM if your still looking. Thanks
Owner of Matt Scott LLC
Specializing in NOS and used Allis Chalmers tractor & implement parts & liturature and Magneto Repair http://www.mattscottllc.com/ |
rtwfarm
Joined: 26 Feb 2012 Location: nebraska Points: 1350 |
Posted: 27 Feb 2022 at 4:24am |
Have some also. Ryan at 402-469-1738
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5279 |
Posted: 27 Feb 2022 at 6:43am |
D14 before serial #D14 19001 used a Delco 1111745
later D14 used 1112593 D15 tractors (series I & II) used 1112607 D17 tractors with an engine serial number below 17-19978 used a 1112584 and the later ones used a 1112693
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 27 Feb 2022 at 8:34am |
They are NOT all the same as Paul posted above. What's the number on your Distributor? I have rebuild Distributors on our website if interested. Steve@B&B bb-customcircuits.com
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 27 Feb 2022 at 9:11pm |
They are pretty easy to take apart and there is not much to them. Rusty parts are easy to clean up with a wire wheel or glass beads. This stuff just costs your time. Less than buying another one.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90897 |
Posted: 27 Feb 2022 at 9:17pm |
what is different on the distributors that would make it impossible to install ONE model on a different tractor.......... say a D15 distrib onto a D14 ?
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Thanks(1)
Posted: 28 Feb 2022 at 7:10am |
Steve ,it's in the advance
Steve in NJ
Posted: 28 Feb 2022 at 3:15pm |
As Fred mentioned, the advance is different. They all will drop in (and probably work) but the centrifugal advance is different from engine to engine. Hence the different part numbers on the Delco tag. When a customer needs a Distributor for his or her Tractor, I always ask them what the number is on the tag. I then give them the same Distributor as an exchange. Steve@B&B
