D-15 governor???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: D-15 governor???
    Posted: 26 Feb 2022 at 4:23pm
Hello
Our D-15 II governor is erratic. It’s ether idle or full bore. Does the the governor need to be rebuilt. Which parts should we make sure we have when we open her up.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2022 at 4:40pm
If you are describing it correctly, it sounds like a broken governor weight. This situation usually has the engine over speeding with about an inch movement on the throttle lever from the slow idle position.  If it was fine until now, something has changed and that usually means governor weights. This is something that happens all of a sudden.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2022 at 6:52pm
Could be a bad governor. However check the the cross arm adjustment is correct first. It may be just be as simple as correctly adjusting the governor cross arm.
bozrae View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 6:15am
Check the link rod from the carburetor to the cross shaft. There should be a spring that goes on the link rod then connects to a manifold bolt towards the from of the engine. I recently bought a D12 from an auction that did something similar to what you described. It seemed to go from idle to high speed with very little travel on the throttle lever and then the governor really didn't respond when under load. The spring on mine was connected to a manifold bolt to the rear of the engine, so it was working against the governor.
The service manual doesn't show where the spring is connected, I looked on a friends D12 to see where it was connected. It works correctly now.
D15D, D17G, 170G, 175D, and two 5050FWA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 7:26am
D-15 does not have that spring on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 8:19am
thank you, tractor doesn’t get used much. Mostly in winter with snowplow. Will look into what you said.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 9:26am
You haven't done a very good job of describing what goes on for sure. Let me put it to you this way. If you have a broken governor weight and you pull the handle throttle half-way down or more, the engine will probably fly apart. Use your tachometer for information !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 8:33am
sorry that’s because I’m not running it. I’ll get more info fro dad
This page was generated in 0.189 seconds.
