Another question- aluminum weights??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Another question- aluminum weights??
    Posted: 26 Feb 2022 at 12:39pm
Seen on Pulloff aluminum weights for sale , WHY would you want aluminum weights ?? There IH , so are they for show ? Whats the point ?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 5:41pm
fake out the competition, or some would even go as far as get certified with the aluminum weights, then swap to the iron ones for a weight advantage. I personally feel it's more of a full rack of weights look more than anything. Competitors trying to copy your front end weight after as great pass.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 7:47pm
Ah good point there Ed , thanks
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 8:30pm
seen it done many times
phil
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 9:42am
Some interesting theories, always thought they were more for show-queens. I know there were/are plastic ones available. Probably 1150 less pounds to drag down the road and still have a full rack at the show!
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 12:27pm
I saw a puller had some skeleton weights this summer, centers cut out, probably less then half a normal weight, with a whole weight on each end you won't know if he is light or heavy on the front.
Edited by DanWi - 01 Mar 2022 at 12:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 12:42pm
They can also be used to closely dial in to the max weight, many times if 50# over, you are stuck with either being 50 over or 50 under, so they are like 1/2 the weight. Some guys have steel ones cut out of various thickness also, to help dial in a gnats @$$ lol!
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2022 at 8:05am
Years ago you had to have a certain amount of moveable weight for some pulling clubs. I heard of a guy that had some made because some scales read a little different and he was that close on moveable weight.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2022 at 9:20pm
Yep... scales that 'read a little different' are either 'rounding', or what we refer to as "defective"... and there's lots of places that have 'defective' scales.
Usually, 'defective' scales show up in places where competitions exist, but not being used in a legal-for-trade application are exempt from regulatory scrutiny, so it's a common avenue for cheating.
