Diamond Roller Chain
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Topic: Diamond Roller Chain
    Posted: 20 Feb 2022 at 3:16pm
Anyone know of any place that has cut to length diamond roller chain for planter drive.  41# chain, will be going on a 8516 Agco/White planter.  Dealer has pre cut chains but it's unmarked so China and I won't run that crap.  Diamond or nothing for me and I use to get it at the local NAPA which is closed now and I'm not having much luck online, at this point I would take a 100ft roll and cut it myself but I haven't had much luck finding any online other than 10ft rolls and that will create a mess of connectors or lots of waste.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2022 at 3:24pm
Diamond has a distributor locator on the web.  You can use that to find distributors near you to call.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2022 at 6:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2022 at 10:47am
#41 is bicycle chain or also used on garage door openers - https://www.usarollerchain.com/41-roller-chain-s/1932.htm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2022 at 7:14pm
He posted he only wants Diamond brand chain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2022 at 7:49pm
The closest Berry Bearing or Motion Industries ( bearing houses) is your best bet.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2022 at 11:33pm
Look up ; Motion Industries and/or Baum Iron, Omaha, Ne. , find the nearest dlrs.
You'll likely buy 10' or 50' rolls. It's not hard to break where needed.
At work we got Diamond #120 and #160 roller from these 2. The Cat & Champiom graders destroyed the cheap when scarifying or cutting V ditches.
