ID A Plow
Armand(AZ) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Armand(AZ) Quote  Post ReplyReply Direct Link To This Post Topic: ID A Plow
    Posted: 23 Sep 2010 at 11:25pm
Can someone tell me the model of this plow??   I thought it is a 2000 but the manual I have of the 2000 shows it without a front wheel.   Tks,   Armand
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2010 at 12:23am
Armand - Per Norm's book, the 2000 series monoframe was a semi-mount in-furrow plow.  At the same time Allis made a 3000 series monframe that was a semi-mount on-land plow.  Allis later came out with a 2nd phase of the 2000 series that had higher frame/trash clearance and Allis dropped the 3000 series but then came out with a 2500 series semi-mount on-land or in-furrow plow similar to the 3000.
I don't know enough to tell from that pic if it's a 3000 or a 2500 on-land plow.   Hopefully someone can point out the difference.  My best guess in comparing that pic to the ones in Norm's book is that it is a 3000 looking at the linkage on the front furrow wheel.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2010 at 6:36am
WOW, wouldn't you like to see that rig in action!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2010 at 6:45am
Ted, the bad part about a rig like that is the plowing would be done too fast.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Armand(AZ) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2010 at 8:14am
Thanks for the info Mike!!   I have a model of the 220 FWA built and in the paint booth and started the plow model a couple days ago.   Then realized that the manual wasn't showing the front wheel assy.  I have the hitch assy and frame built so I guess I will need to decide if it is going to be an in-ferrow or on-land unit depending how it lines up with the tractor.   :>)   There's a few pictures of the  220 on my website at acmodelsofarizona.weebly.com      Armand
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2010 at 10:49am
That is a 3000 series, 2500 series had more clearance.
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2010 at 6:01pm
That is a 3000 Series Semi-Mounted plow. With the proper hitch set-up the tractor could run on land, or in the furrow. The 3000 Series was available with 6 to 8, 16 inch bottoms.  The 2500 Series was a Pull Type, and had 5 thru 8, 18 inch bottoms.  This info came from my A-C plow Operator's Manuals.
