WD45 Exhaust gaskets/ keepers
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Exhaust gaskets/ keepers
    Posted: 18 Feb 2022 at 3:54pm
Help! So I bought all new exhaust gaskets for my WD-45 manifold and the outer two that are shaped uniquely square on the top and bottom are not wide enough the metal part is not wide enough to fit over the manifold I need ones that are one and a quarter inch wide at the top and the bottom of the square part. Can anyone help me? 🤔😂. As always Thank Y’all. Dana
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 8:19pm
Spread them out and put them on or do dome grinding on manifold. Probably a after market manifold.                         MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 11:33pm
I thought spreading them out will leave areas with no metal to hold the gaskets in place and will eventually erode out the gaskets and leak exhaust? I was hoping where to buy correct fitting ‘square end’ metal gaskets. Yes CHINA is stamped on the back side.
                          Dana
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2022 at 7:33am
The problem is not the gaskets being wrong, the problem is the way the manifold is cast. Listen to Mack....... If spreading the gaskets will not work, grind the sides of the manifold down until the gaskets will fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2022 at 1:03pm
Yup Thanks. Dana
                          Dana
This page was generated in 0.071 seconds.
