Power director clutch
John m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Topic: Power director clutch
    Posted: 18 Feb 2022 at 3:15pm
Working on a 190xt power director clutch. When taking the clutch pack off I discovered there are no steel balls beneath the Allen screws that secure it to the shaft. The repair manual says there should be 1/4 Chrome steel balls. Should I just find some balls to put in when reassembly or is they not used anymore? Thanks, John
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 3:49pm
Steel balls were not used in the very early years and were added as an improvement.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 3:51pm
You can use 1/4 chrome balls
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 3:54pm
Thanks, I'll find some 1/4 inch balls and put them in when reassembling. The Allen heads weren't very tight when I removed them. This may keep them snugged up.
This page was generated in 0.238 seconds.
