WD Transmission (early)
brownsmule View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brownsmule Quote  Post ReplyReply Direct Link To This Post Topic: WD Transmission (early)
    Posted: 23 Sep 2010 at 3:57pm
Hello; I need the part number of the needle bearing that goes inside the input shaft and over the end of the pinion shaft on the early style WD transmission.  If anyone has a part's book, I would appreciate the look up.  In addition; I have a replacement pinion shaft for same and how difficult will it be to change it out; any special tools; and time estimate.  I need to get it repaired and out from under the shade tree.  Thanks in advance
brownsmule
